I need the manual for model number for a carrier puron 38TDB060310
  • 958 Answers
SOURCE: Carrier indoor coil replacement
yup, entire system needs to be drained, and leak needs to be repaired first before charging with freon.
after sealing the leak and test it is ok, evacuate the system for about 30 mins before charging it.
you may need a qualified tech to do that because you can not buy freon now a days.
you need to weld the leak also. you will need portable torch to weld copper pipes.
you will need vacuum pump to evacuate the system before charging with freon 22.
tnx 4 using fixya,
drcool
Posted on Sep 18, 2008
rockitman187
  • 2559 Answers
SOURCE: AC will not cool. How much should a service charge cost?
If the upstairs is working and the down stairs is not,You only need to have one unit checked,Don't assume it just needs puron(If it does,You have a leak,which cost more to locate and repair than some other likely causes)This is not something you can do yourself and is illegal if you are not EPA certified.to get a fair price would depend on your geographic location and the best way would be to call around to some local heating and air companies and ask how much a service call is.(That only tells you the price for them to came and see what the problem is,They will not be able to quote a price until they know what must be done to make the repairs.
I hope this has answered all your questions.
Please take time to rate this fixya
Posted on May 16, 2009
autobohm
  • 6 Answers
SOURCE: What size is a Carrier model number 38EH036350DL?
Main house central air? = 3 tons
Posted on Aug 19, 2009
Testimonial: "Thank you for the help."
SOURCE: Need to find out how many ton's my Carrier Puron system is rated
your tonage can be determined by the model number for example 018 is 1.5 024 is 2 030 is 2.5 036 is 3 048 is 4 060 is 5ton
Posted on Feb 25, 2010
heatman101
  • 43501 Answers
SOURCE: Central A/C unit
That would be a 2 ton 24000 BTU unit
heatman101
Posted on Apr 23, 2010
Testimonial: "Very fast and helpful response to question. Thank you!"
24ABA342A30010 NEED TO KNOWHOW MANY B T U'S THIS UNIT HAS
The only important part is before the last A. It gets broken into two parts, xxABA, and *** (where x is any number)
24ABA:
24A = A/C (24H would be heat pump)
B= Base series, C would be Comfort, P would be Performance and N would be Infinity. (B, C, P, N in that order gives you more bells and whistles)
3rd letter = A (puron) or B (R22).
342:
First number = SEER 3 = 13, 6 = 16, 1 = 21.
42 = btu in thousands (18-60)
This means that your unit is a 13 SEER, 42,000 BTU base-model Air Conditioner which uses Puron (R410 refrigerant).
Aug 22, 2011 | Carrier Heating & Cooling
I replaced my whole heat pump system 3 years ago with a Carrier Puron unit. The installer called me this week and told me that I needed to replace the puron after the third year at a approx cost of...
Tell him you already had it done. lol. Unless you misunderstood what he told you no! You don't need to replace the Refrigerant weather it's Puron or Freon. It doesn't wear out. Ever. If your system develops a leak and you loose the Refrigerant it will have to be replaced but you will know you lost it because the system won't cool and heat like it's supposed to. I would report the installer to the better business bureau.
Aug 31, 2010 | Carrier Heating & Cooling
Central A/C unit
heatman101
Apr 23, 2010 | Heating & Cooling
Feb 25, 2010 | Carrier Heating & Cooling
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
May 16, 2009 | Carrier 38CKC036 Air Conditioner
tnx 4 using fixya,
drcool
Sep 18, 2008 | Carrier Heating & Cooling
Carrier air conditioner problem
My Carrier unit did the same thing. It was low on refrigerant (Puron in my unit). I am worried I have a leak somewhere. Hopefully, it is not in the coil. The service call wasn't cheap either. Puron runs around $10-15 a pound and mine took several pounds to replenish.
Aug 01, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
