Question about Whirlpool Refrigerators
Needing to replace shelving for refrigerator door middle & bottom shelves.
  • 725 Answers
Send you model number and I will check
Posted on May 26, 2008
Fridge door hinges on right door dipping to the left how do i adjust
First take some weight out of the shelves on the door. To much weight in shelves will make door sag.
Mar 03, 2013 | Zanussi ZX99 / 5 Bottom Freezer...
I need a door shelf for my Frigidaire side by side refrigerator (# FRS6R5ESBFPN # 241691311)
  • You did not list freezer door or refrigerator so I will link you to all of them and you can choose the one you need. These are all for Frigidaire FRS3R5EMB
  1. Upper freezer shelf - http://www.appliancepartspros.com/Appliance-Parts/frigidaire-bin---door-frzr---upper-item-number-ap2115843.aspx
  2. This one is a replacement for the lower 3 freezer shelves http://www.appliancepartspros.com/Appliance-Parts/frigidaire-freezer-door-shelf-item-number-ap2115974.aspx
  3. This one is a replacement for the 2 bottom shelves of you refrigerator http://www.appliancepartspros.com/Appliance-Parts/frigidaire-refrigerator-door-bin-item-number-ap2115741.aspx
  4. This part here is for the 2 upper shelves of your refrigerator http://www.appliancepartspros.com/Appliance-Parts/frigidaire-refrigerator-door-bin-item-number-ap2116036.aspx
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Refrigerator door not shutting correctly, not a good seal. could it be the little spring arm at the bottom?
check the gasket around the door,also make sure nothing is hitting on the shelves,if you have to remove some of the food,check the shelves and make sure they are back all the way,i've seen the bottom draws and shelves not in correctly,they stick out farther than they should hitting the door,remove the glass shelves that are on top of the draws and see if the door closes.let me know how you make out
Nov 28, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Broken Shelves
The only shelves you'll get for this model is probably the ones offered by the manufacturer.
The best way for longevity of the shelves, is to make sure that you do not put too many heavy things on it, and be careful when cleaning and replacing shelves..
May 28, 2008 | Frigidaire FRS3R5EMB Side by Side...
Fridge part not cooling properly
Miss Sugarbaker, it almost sounds like a airflow issue, but check to see if the interior light is going out when the door is shut. This would cause the higher temps on the top shelves. The damper assy. is controlled by a thermistor that sends the temp info to a main board in the back. If this thermistor is bad, the damper will not funtion properly. Catriver..post back.
Sep 27, 2006 | Hotpoint HSS25GDMWW Side by Side...
Refrigerators Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
