Question about Mitsubishi WT-42311 42" Rear Projection Television
When i press power the timer light flashes and the T.V. turns on and right back off.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If model number is WT-42311 do the self check the set has.
When power light comes on and then goes off, on front of set press both the Menu and Input (device) buttons at the same time and hold for at least 5 seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and the repeat the code several times.
Let me know what the error code is and I will tell you what it means.
If this has helped you, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Oct 03, 2010
  • 1 more comment
  • jmjjjones Oct 18, 2010
    I did this with mine and the power light blinked twice over and over again can u tell me what that is?
    Thanks
  • jdstmv Nov 16, 2010
    I have the same issue with the WT42311 model. Did the Menu and input and got 2x2 blink. What is the problem so that I could decide whether get it repaired or replaced, to close to the holidays for another tv.
  • perryfam04 Mar 15, 2011
    When following your directions it blinks two blinks a short pause and then another two blinks. Any ideas?
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
How to reprogram my Woods N1506 Timer
Manual and image for Woods/Noma N1506 outdoor timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
Timer is only set to nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Dec 13, 2010 | Woods Outdoor Lighting Timer
How do I program a Noma N1506 timer?
All Woods timers and manuals
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do I set the Woods N1506 timer?
N1505 timer manual:
Dec 01, 2010 | Woods Outdoor Lighting Timer
Model N1506, I need Operation instructions for this Woods Light Timer?
N1505 timer manual:
Dec 01, 2010 | Hardware & Accessories
How do I set my Woods N1506 timer?
According to another fixya answer posted December 4 2009:
FOR MANUAL OVERRIDE
Nov 23, 2010 | Woods Outdoor Lighting Timer
I need instructions for using my N1506 timer.
Plug in timer – The letter C will Flash
Press Time Button – It will advance to 1 a.m.
Press Mode button – Letter P will flash inviting you to set the program
Press Mode button again – the letter E now flashes.
Press time button – Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
FOR MANUAL OVERRIDE
Dec 04, 2009 | Woods Hardware & Accessories
Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Nov 19, 2009 | Heating & Cooling
Projector suddenly shut down
you need to reset the lamp timer. turn it on, and press and hold the left arrow, right arrow, and power button until it resets.
Dec 17, 2008 | Mitsubishi ES100U Multimedia Projector
Mitsubishi WT-42311 42" Rear Projection Television Logo
820 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
