Question about HP Photosmart 3210 Printer
Ink System Failure
I've tried new ink, holding in "ok" and shutting off system, unplugging it, holding "ok" "cancel", "color", and "black" etc.... nothing is helping, Everytime I turn on my printer ( HP Photosmart 3210), It gives me a "Ink System Failure" "Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc5d1381" (by the way, it says unable to receive fax, but it doesn't have a fax on it)
  • Anonymous May 29, 2008
    I have tried all the solutions given for this problem, but nothing has worked. This has been a pain in A%% printer since I got it.
  • Anonymous May 01, 2009
    Nice copy paste Khalsa007. Did you get that right off the HP web site? Doesn't work. Does any one have a real solution? Like when you hold down the two keys at the end of the #'s pad and it comes up with the msg of: Mfg Commands - Enter Special Key Combo............. What's the combo?
  • 3 Answers
I just had this problem with a HP C5150 and I found this bit of conversation on the web and it worked for me.
My error code was 0xc18a0501 and the following steps did resolve my issue, hope it helps you as well.
  • OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech.....
    james cowan: hp error code 0xc18a0001
    Earnest: I will assist you in this regard
    james cowan: great
    Earnest: I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
    james cowan: correct
    Earnest: Thank you for confirmation
    Earnest: May I have the model number of All-In-One you are using?
    james cowan: c6250
    Earnest: Thank you for information.
    Earnest: James, please let me know the room temperature in which printer is replaced
    james cowan: 67 degrees f
    Earnest: Okay
    Earnest: Please perform the below steps on the front panel of the printer to resolve the issue
    james cowan: ok
    Earnest: Press and hold the "left arrow" key.
    Press the "Setup" key and release both keys, Display should say "Enter Special Key Combo"
    Press and release the "OK" button.
    Earnest: Please ignore the above steps, James
    james cowan: ok yes nothing seemed to do anything
    Earnest: Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
    Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal"
    Earnest: Display should say “Support” and display the FW rev (something like R0616R)
    james cowan: COxxFN0723BR j
    Earnest: Okay
    Earnest: 2. Press and release the right arrow button until the display says “System Configuration Menu
    james cowan: ok
    Earnest: 3. Press and release the "OK" button.
    james cowan: ok and it says hardware failure status
    Earnest: Display should say "Hardware failure status: Clear. Press OK to clear".
    Earnest: Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    Earnest: Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    james cowan: ok
    Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    Earnest: Let me know once you are done with the above steps
    james cowan: ok its unplugged
    Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    Earnest: Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
    james cowan: ok
    Earnest: Let me know the message displaying on the front panel of the printer
    james cowan: printer preparation occuring - do not interrupt
    Earnest: Okay
    james cowan: ok its done
    Earnest: Let us print a self test page from the printer now
    james cowan: ok deal
    Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray.
    2) Make sure that the printer is on and loaded with unused plain, white paper.
    3) Press Setup . The Setup menu appears.
    4) Press the down arrow button to select Tools , and then press OK .
    5) Press the down arrow button to select Self-test Report , and press OK .
    james cowan: ok printing
    Earnest: Okay, please check whether all the colors pritned perfectly on the test page
    james cowan: perfect
    Earnest: Great..Cheers!!!
    james cowan: thank you very much
    Earnest: James, now you can continue using the printer
    Earnest: I appreciate your efforts and patience in trying to resolve the issue."
Posted on May 02, 2009
    Novelist:
  • 79 Answers
The issue relates to hardware of the unit ,
unit can not be recovered or is almost certain to fail again, however we can Attempt to Recover Unit Once .follow the steps below .
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Reconnect the USB cable, and try to print a print job from the computer.
9. If the error is still there replace the unit.
it might help.
Thanks.
Posted on Jun 05, 2008
Printing problem hp D7160 error 0xc18a0001 please help
Hi,problem can be solved .Please check out this link for the Ink System Failure problem.
fixyourownprinter.com/forums/printer/39471
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
Our HP 3310 was having the same ink system failure. Tried everything I could find, and had just about given up when I found this forum. I didn't quite get the reset right the first time, but on the second try it worked. After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again.
Also
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
Hope this works for you. Please let me know.
Oct 28, 2010 | Office Equipment & Supplies
INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013 Press OK This is the error in which I am receiving and I need to...
The Ink waste tank filters are usually change by a technician or the counter can be turned back. The ink waste tank is found at the base of the printer
Aug 08, 2008 | HP Photosmart 3210 Printer
Ink system failure
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jul 30, 2008 | HP Photosmart C5180 All-In-One InkJet...
How do i repair: hp Photosmart C7280 Printer ink system failure error: Oxc18a0101
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Jul 18, 2010 | HP Photosmart C7280 Printer
Ink failure error OXc05d1281
Reset the system by holding down the OK, Cancel, Black, and Color buttons at the same time and turn the 3310 off. You should keep holding the buttons down until the printer shuts off and then turns itself back on. Turn the printer off twice for the printer to recalibrate. Make sure you have new cartridges in the printer so that it can reset.
May 12, 2010 | HP Photosmart C8180 InkJet Printer
My HP C7180 will not print the self test diagnostic page the screen on the product says ''paper mismatch'' paper size or type is incorrect,change paper and press OK. when I do the machine shuts down then...
Your cartridges have chips on them and a date i think. So, my guess is, that the printer is alarming you that the "ink expiration is near", because soon, the chip will not allow you to print anything, so you will have to buy new ones.
The only reset method I know is used for "ink system failure" (Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the printer off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate). But you need to have new cartridges for that.
Mar 08, 2010 | HP Office Equipment & Supplies
Ink system Failure Error Oxc18a0001
Hold the number 9 key and the key down at the same time, then pull the power cord. Then put the power cord back in while holding the 9 and # key. You will lose your settings, but the ink system failure message should go away.
Jan 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 3310 all in way Error Ink System had Failed 0xc18a0101
I had this same exact problem. Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
After I did this my printer reconfigured like it used to do and it was like it was new again.... well new plus a headache a managed to get while reading all these little posts. I hope this helps!
If not try going to this website:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers
Apr 05, 2008 | HP Photosmart 3310 Printer
Ink system failure
Turning the printer on and off will not solve your problem. If you get ink system failure you most likely have air in your ink system. This will happen after months of use -every ink cartridge you reload and purge will have a little bit of air trapped in it and over time it must add up. You have to do a system reset which causes your printer to start over and do a full purge of ink through your system. This is what happens when you do your first ink system set up when you open install new ink cartridges. To do a ink system reset you must first:
1. After your printer gives you a ink system failure you will need to press and hold down ok and cancel at the same time and then press the start button once. (make sure you hold the cancel and ok down until the system shuts down and then release).
2.Now (Again) hold the cancel and ok Button down and and press the on button again -making sure to keep holding down the cancel and ok until it shuts itself down again. It will seem like it is starting up again up will then just shut off. Now once it has shut off for the second time (It is VERY important that you have a new set of ink cartridges installed before turning on the system for the second time) This is because it will do a full ink purge and rid the trapped air in the system. If you have old ink in it or almost empty it will most likely not purge enough. A new set of ink works best- You can go back to your old ink after if you like and keep the "new" set for back up when the system fails again down the road (it will fail again -this is poor designing by HP).
3.Now once you have shut down the system and loaded a fresh set of ink (all 6 of the ink cartriges) you can now press the on button (at this time you should get a reset code the come on first and the printer will run its purging of the air and new ink.
4. You might have to do this more then once to rid all the air out of the system-keep trying and after 2 -3 times it will stop giving you the ink failure. I have fixed my printer many times by this fix for many years.
Good Luck!
Sep 27, 2007 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
849 people viewed this question
Ben Johnson
