Question about Acer Computers & Internet
My monitor keep blacking out each time I attempt to scroll a page
  • 78 Answers
Try to adjust the resolution of your screen go to your desktop wallpaper. right click and then hit on properties. it should pull up another window. hit on ADVANCED you should be able to see there Screen Resolution. drag it down to lets say 1024x768 and hit apply.
now check if its still doing the same problem.
Posted on Oct 03, 2010
My proview monitor stays on for 10 sec then goes black. but i can faintly see my page.
This indicates an inverter board failure, caused by bad capacitors that sometimes bulge at the top showing that they are open, an attempt can be made to repair or replace the board.
Mar 05, 2011 | Proview PL926WBi 19" LCD Monitor
UF8000..HOW DO YOU CLEAR MEMORY. RECEIVED A 200 PAGE DOCUMENT (NOT AUTHORIZED) KEEPS PRINTING. HOW DO I CLEAR THIS FILE
turn unit off/on press function,original size,3 will be in service mode should say f1 if done correctly go to F9 scroll till it says ram initilize,hit start scroll till it says all job clear!start unit will reboot should be good to go!
Dec 13, 2010 | Panasonic PanaFax UF-8000 Laser Fax
My Monitor will not say on. Keeps turning off or Black screen when i click to do something. I am using my Laptop to ask this question
blorip, You will need to prove that x193w lcd monitor also does same when connected to different "known-good" pc!! Learn how to tell the difference between a "black screen" and a "black n blank screen" with use of a bright flashlight held 1 inch from lcd panel and at different angles. Yes, there is a difference!!! If problem proves not to be PC software, then must be problem with ccfl back-lit lcd display. You should view DIY repair and disassembly video clips at YOUTUBE before attempting to do any repairs to your Acer unit. Read some stuff in my fixya profile( pages 30 and up) for more info and links. Also view fixya profiles of "budmrtn" and "buddymc" . Follow links you find in profiles. Good luck with the repair. 12fixlouie
Jul 26, 2010 | Acer X193W LCD Monitor
HI, I have a NEC monitor 1760nx, dark blotches on the screen
Listen, for what it is going to cost you to fix the unit, you are better off replacing it and having a new warranty to boot. Simply not cost effective to repair given the cost of a new monitor these days.
Mar 12, 2017 | NEC 1760NX-1 (White) 17 in. Flat Panel LCD...
Been receiving blank pages on random incoming faxes. Multiple error codes, but the one I can't find in the manual is code 212. This error code keeps reoccuring along with others.
Press the following keys:
Function
7
monitor key slowly 4 times
* star key
6
scroll down to SHIPMENT SET
set
wait for the machine to reboot.
Jan 08, 2010 | Panasonic Panafax UF-885 Plain Paper Laser...
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
How can you clear the memory in a Panasonic UF 4100? There is a message of over 50 pages that is just a thick black line throught the middle of the sheet, we just want to clear the memory to get rid of it....
if the memory has not cleared it self by now...try this
Remove the paper
Press
Function
7
* (star key)
6
scroll down to ALL JOB CLEAR
set
wait for the machine to initialize.
Nov 04, 2009 | Panasonic Office Equipment & Supplies
My monitor has a horrible lag
Your monitor should have a reasonable to good refresh rate so I doubt it's at fault. It sounds as if you have another program running in the background which is slowing your computer down. Press the keys CTRL. ALT and DELETE at the same time and have a look to see what's running. Close down any programs you aren't using and see if that fixes things. Another problem could be a shortage of memory. I'd recommend no less than 512 Megabytes or ram with Windows XP. If you could give me more info as to which operating system you're using, how fast is the CPU and how much memory etc it would be easier to diagnose. One last thing, you could have a virus and it's chewing up memory. Do you have an up to date virus checker? If not install AVG. it's completely free and available on the net. While you're at it install a spyhunter program and malware checker. There's some weird rogue nasties crawling all over the net. You could've even installed a nasty along with a freebie program you got off the net. BMW
May 31, 2006 | Dell E193FP 19" LCD Monitor
Computers & Internet Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
