Question about Kenmore HE2 Plus Front Load Washer
Why does it keep on throwing the breaker? - Kenmore HE2 Plus Front Load Washer
  • Kenmore Master
  • 12,061 Answers
Hi, the reason this unit, any unit, is tripping breaker, blowing fuses, is that you have a short circuit, somewhere in the unit, between the Phase Wire and Neutral/Earth.
Usually this is on the main PCB, but in reality, it maybe anywhere within the unit.
With a problem such as this it is nearly impossible to tell exactly where the problem lies, without performing the troubleshooting steps, accordingly i have given you a link below to download your Service and repair manual, also i have included a DIY help site as well.
http://www.acmehowto.com/howto/appliance/washer/washer.php
Above the DIY help site, below service manual.
http://appliancejunk.com/forums/index.php?topic=2946.0
Posted on Oct 03, 2010
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
My Dayton arc welder model no.3z564 keeps popping the breaker it was working then all of a sudden started throwing the breaker.
take it to an accredited electrical shop that repairs welders as there is a dead short in the circuit.
Oct 29, 2014 | Welding Tools
Why does AC Duo-Therm thermost throw the breaker and needs set to approx 55/50 to run ?
`Try changing the breaker some times they get weak and will trip at start up. Also check for bare wire shorting out. Then check capacitor then fan motor spin blades to see if they spin easy and that bearings are not bad.. make sure all connections are tight with no corrosion. These problems show up more with short cycling then with long.
Jun 27, 2014 | Dometic Rooftop RV Air Conditioner
Hatco booster blowing breakers
Copy following link:
http://waterheatertimer.org/Water-heater-is-blowing-breaker.html
Hatco booster heater typically has 2 sets of thermostats and elements located on each end of heater.
Both sides might be controlled by same 60 amp breaker, or the heater might be controlled by two separate 30 amp breakers.
Be sure you have correct wire and breaker.
After reading steps on link above, add comment and say if this is new installation, or older installation that suddenly started throwing breaker.
Apr 08, 2013 | Hatco 208/3 C-12 Compact Booster Water...
Our generator keep throwing the curcuit breaker.
Check to see you are not overloading the current rating of the breaker. If not the breaker may be worn out and need replacing
Oct 16, 2012 | Coleman Powermate Premium Plus 6250W...
Outside ac unit breakers keeps breaking
Check all wiring for loose connections, particularly at contactor. Check for short circuit and earth leakage
Apr 21, 2012 | Heating & Cooling
The air condition in my 2006 Lardo 5th wheel keeps throwing the breaker sometime it will run 15 minutes or 4 hours then throw the breaker
You could possibly have a weak set of breakers. If you have access to an amp meter, clamp around on of the wires coming from the breakers so that you can measure the amp draw. If the amp draw of the unit (when running) is lower than the breaker rating, change the breakers.
The other problem could be a stopped up rear coil. This is the part that looks like a small radiator the the hot air blows through on the roof. You will have to take the cover off the unit to see the inside of the coil. Look through the rear fan blade and you will be able to see if the condenser coil is stopped up wit dirt etc. Hope this helps.
Aug 07, 2011 | Dometic Rooftop RV Air Conditioner
A/C runs for 10 min then throws breaker
the 30amp breaker is bad but when running on a 20 which is good its not enough of amps to support thats why it ran for 2hours before it ..so try changing that breaker to a new one
May 15, 2010 | Coleman Mach III Air Conditioner
Duo-therm 13500 btu
First I would check the size of the power supply cord to the coach. To small a line will cause a voltage drop which in turn will cause the amperage to increase. Check the supply voltage to the system.
Jun 16, 2008 | Dometic Rooftop RV Air Conditioner
Breaker keeps throwing
jhweis80 Why do you think the problem is the dryer? The circuit breaker itself could be bad and this is what I will check first. Probably you need a professional electrician to do it for you. Gendos post back...
Jun 27, 2007 | Maytag Neptune MDE6700A Electric Dryer
Kenmore HE2 Plus Front Load Washer Logo
371 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
