Question about Samsung SCX-4216F All-In-One Laser Printer
My SCX-4521F Scanner is not working. "System Cannot Found" - Message pop-up on my PC whenever I tried to do scanning. An unknown characters appeared on my Samsung All-in-One Laser Printer every time I do the scanning. Please help. Thank you
  • 33 Answers
1. Reconnect the PC and printer, replace any faulty
cables. If using a parallel cable, check that the parallel
port is properly configured in the BIOS.
2. If printing is OK check that the Scan driver is also
installed
Posted on Oct 03, 2010
Unlocked samsung scx 4521F scanner
PLEASE REFER TO IT MANUAL. IF NOT FOUND IT PLEASE CONTACT THE NEAREST MANUFACTURE IN YOUR AREA
Sep 11, 2012 | Samsung SCX 4521F All-In-One Laser Printer
The message window says "scanner
There is a PHYSICAL "tie-down" mechanism (compare to a seat-belt in an automobile)
that prevents the scanner-head (or the occupant of the vehicle) from moving during transport.
Unlock that mechanism (open the seat-belt).
Jun 15, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How do I activate the scanner on the SCX-4521F multi function printer?
Click this link http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=N0000191&model_name=SCX-4521F
Go to Scanning, then How to scan.
You have to configure the printer first to scan. Follow the steps and you should be all set
Feb 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
My printer does not scan. i have message scanner locked . Model scx-4521f
There are 2 problems:
1.contact image sensor (CIS) in scaner unit
2. ***'Y PCB MAIN
Jun 22, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How to scan a document on the scx-4521f
hi,
here is the the user manual for scx-4521f scanner. this will guide you to use the scan feature of the device.
cheers
Jul 23, 2009 | Samsung SCX 4521F All-In-One Laser Printer
SCX 4521F scanner driver will not configure. Have tried repeatedly to download driver, download looks ok, but scanner never appears. SCX 4521F works fine as a printer/copier.
The problem is the firewall of your computer because its blocking the scanner to work better. Check the firewall of your computer from it is control panel if its on. If it is on, click the exception tab then check the network scanner tool and scan to pc box. Just put acheck on all scan or scanner word.
Jul 16, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I HAVE Samsung SCX-4521F All-In-One WOULD YOU ANSWER ME PLZ
Please chepue out the scanner ccd is not moving properly
when ccd is stop in one place the image will come sreached
or check the scanner cable or check ccd
May 10, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Problem scanning with samsung scx 4521f
Sorry to have missed your initial posting...
In any case, to my understanding, this particular printer is likewise capable of USB connection. Perhaps you can try connecting it pure USB and go through the installation again. this might simplify interface and communications between notebook and scanner/printer.
If for some reason you would want to retain Printer/Parallel to Notebook/USB, you need to check your Imaging Devices in the notebook's Device Manager and verify that all drivers are installed for the Samsung SCX-4521F. There should be no yellow or red marks. If there are or if the Samsung SCX-4521F instance is not present, you may need to reinstall using the Add Hardware Option in the Control Panel. You may need to manually select the imaging device/scanner. This holds true if you are using Windows XP.
If you are using Vista, you may need to download all the Vista drivers from the Samsung website. Further, pls be informed that to my knowledge, Vista has certain issues with USB ports. Microsoft has issued a patch/update specifically for this concern. It may be downloaded from here or here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Cannot operate scanner
Just posted two solutions to my problems. see here.
http://www.fixya.com/support/t134648-scanner_not_working
Hope it helps
Nov 02, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Scanner not working
Samsung can be cheeky with support i have found and not as helpful with tech help. Instead of going off in tiny circles with unlocking etc, i would go for the quick fix and suggest your scanner may not have installed properly when you installed it. As you have installed the drivers again with no luck i would even suggest goint to samsung web site and downloading new updated drivers for your printer to eliminate corrupt drivers. Does you pc register the scanner being there? Go to control panel, hardware/ printers, find your printer and check all the drivers and whether scanner is actually present on the pc here.
Aug 30, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
152 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
