Question about RTO Basement Watchdog Sump Pump
Battery has liquid on top - RTO Basement Watchdog Sump Pump
  • 760 Answers
The battery is charging with trickle charger. The liquid could be just water from condensation from the recharging process. If the charging is too vigorous, then it can also be sulfuric acid, so rubber gloves are in order. Clean up liquid with gloves on and paper towels. Once dry carefully remove caps and check water level. refill battery with distilled water to top of cell. Check water level at least twice a year. Wear safety glasses too.
Posted on Oct 03, 2010
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
There is a green liquid coming from the carborater an the car won't start what could it be.
the green liquid that i am familar with is anti freeze, but i have not seen it around the carbuertors, unless a top radiator hose was leaking from the thermostat housing, and it got over to that area. is the battery charged up, make sure the battery connections are tight and clean, is the starter turning over or just clicking, if it is clicking, could be connections, or starter solenoid, or the starter itself.
Feb 13, 2011 | 1990 Oldsmobile Cutlass Calais
Remote control stopped working, changed batteries and still voume & on/off switch not working. All other functions okay. PLease advise problem & solution Thanks
For this you have remove the outer cover of the remote and wash the top portion of the remote(PCB board)with any volatile liquid like spirit,petrol.
Jan 13, 2011 | Sharp Televison & Video
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
!998 Dodge Caravan is leaking a clear liquid left of battery.
antifreeze by the sound of it ,but it could be battery acid from a damaged battery casing
May 16, 2010 | 1998 Dodge Caravan
How do you put the liquid soap dispenser back
The "bottle" screws in from the bottom. The "pump" is inserted in the top. I usually fill mine from the top without taking out the bottle. Too much of a pain. Just make sure the large nut holding the hardware in place is secure before you start assembling the bottom and top. If it's loose, the whole thing will wiggle around. Good luck!
May 07, 2010 | American Standard Contemporary Kitchen...
My son Dumped some kind of liquid on my LG Rumor and now it is white screened.
Please take note; once a phone drops into water or any liquid, first thing you need do is to remove the battery, get a phone screw driver, loose the phone and dry the phone board with bulb or any heat.
The essence is to dry the water totally from the board, because if it dries itself, the phone board will get rust and phone might not work properly again.
Back to your phone, I think the liquid as entered your screen and its not dry yet, that's why its white.
Put off the phone, remove the battery and leave the liquid to dry on the screen or put is near a very light heat and the liquid will gradually dry off.
Try it, it will work.
Take care.
Dec 30, 2009 | LG RUMOR Cellular Phone
Samsung A737 water damage..??
the little square that you are referring to is a liquid damage indicator, it will change it's color if the phone is exposed to any kind of liquid or moisture.
Jun 27, 2009 | Samsung SGH-a737 Cellular Phone
Can not get battery out
If this is an alkaline battery, it may be stuck due to corrosion. I would carefully slide a solution of liquid soap and water going a little heavier on the soap. Dial soap is perfect, and let it sit for 24 hours. The batteries should slide right out. Try it
Jan 11, 2009 | Camping, Backpacking & Hiking
Battery charger-leaking yellow liquid
No, it will not be safe to use it again, and yes, the yellow liquid is VERY DANGEROUS. Please do not use it again, you need a new charger.
i dont think the batery was affected, but if it was, you also need to throw it way and get a new battery.
Jun 07, 2008 | Sony Ericsson Z710i Cellular Phone
RTO Basement Watchdog  Sump Pump Logo
441 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
