Question about Maytag 30 in. Electric Single Wall Oven with Precision Cooking System Feature
Oven is not working; Code F1 appears. - Maytag 30 in. Electric Single Wall Oven with Precision Cooking System Feature
    Genius:
  • 1,417 Answers
This error code on a Kitchen Aid range indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-yourselfer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
thank you and thanks for using fixya
Posted on Oct 03, 2010
  • Anonymous Oct 03, 2010
    hello,
    This
    pcappliancerepair.com appliancepartspros.com repairclinic.com
    the average do-it-your self offer. If you decide to order the part and wish
    the board.
    Please rate this solution
    Thank you and thanks for using fixya.
I put my Frigidaire Electrolux oven in cleaning mode an hour ago. It is now beeping non stop with "F1 Err" on the screen. Nothing I push seems to work
The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement.
If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC).
- If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven.
- If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary.
- If the oven is actually overheating, replace the EOC.
- If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Visit THIS LINK for additional detail
Jul 19, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
F1 code on GE Profile Range. Model # JGSP40AES2AG Oven Sensor checks 1100 OMHS at 79 degrees and drops to 980 when cooled in 66 degree water. Oven temperate is maintained when oven is used. F1 code...
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the electronic control/clock assembly. You can try ebay for a new part and check this video for repair:
Please get back to me if you have any other questions.
Kevin
Apr 15, 2011 | Ovens
Our monogram double wall oven has a f7 code on the control panel. None of the buttons appear to be working, except clear, which clears the code. Then still no buttons work, and the f7 code comes back. What...
It's most likely that the error code you are seeing is F1, not F7. F1 is a code for 'stuck touch pad'. You will need to replace the clock/ERC or the touch pad (or both).
Feb 28, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
What does error code F1 E1 mean on a kitchenaid built in oven?
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Feb 14, 2011 | KitchenAid KEMC378 Electric Double Oven
My oven is beeping and the F1 code and F7 code are appearing on the screen
Hi
F1 indicates a fault on the electronic oven controller (the clock) & F7 means a function key is stuck.
Check all the keys on the keypad if the fault remains you probably need a new clock.
Dec 19, 2010 | Thermador SC302T Electric Double Oven
Oven has error E1 F1 will not work
F1 - E1
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Jan 11, 2009 | Whirlpool RBS275PD Electric Single Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
F1 Error Code
According to the GE website, F1 usually means a problem with the keypad. You might try my solution for the F7 problem which is similar in nature. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my solution with more than 1900 folks and most report success.
Please let me know if it works for you at:
hutchipop@yahoo.com
Good Luck,
Powerman
Jul 16, 2008 | Ovens
Error code F1 and beeping
Means replace the $300 control board. And if your like me.....do it twice within 12 months.
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Maytag 30 in. Electric Single Wall Oven with Precision Cooking System Feature Logo
123 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
