Cannot shift out of park.
Where do you get that part? mine's broken too. i put a nut the size of the tube and it works for now but would like to get the real part.
I had the same problem-my jeep was stuck in park. I pulled off the shifter knob (where you push the button on the side) and found out the plastic rod inside had broken. I took a plasict clothes hanger and cut a piece the same size as the broken piece and and put the knob back on and it worked perfect!!! This solution works just fine, although I do plan to replace the broken plastic part. But, at least I can drive it for now.
Hope that helps.
Hi
2004 jeep wringler is stuck in park.
kent56
Is the jeep on a steep hill if so try rocking the jeep back and fourth while somone is inside trying to shift.
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
1996 Toyota Corolla: Transmission
Shift Interlock will not Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
Gear
indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of
Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high
gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Buick Park Avenue: Transmission will
Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while
driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html----transmission sticks in first gear?http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html-----Transmission not engaging in first gear?http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html-----Vehicle only goes in First gear?
----Engine will not go out of park mode?http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html----Car stuck in park?http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html-----Car will not come out of Park?
Automatic transmission will not go into high gear?
---Car wont downshift sometimes?
----Transmission will shift into drive?
-----Auto wont shift from park?http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html----Car Transmission will not go into Park mode?
-----Shift indicator directly goes to 2nd when key is turned ON?
----Third gear missing and engine losing power?
-------Vehicle has whining sound in gear?
-----Hard to shift gears on Manual transmission?
------Car hard shift at slow speeds?
---Automatic transmission shift lever hard to move on cold mornings?
------Gear shifts hard?
-------Vehicle noticed sluggish delayed shifts while driving?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
stuck in park
2003 Jeep Wrangler Stuck in Park. I noticed it was a little difficult to place in park when I pulled in. Now it will not come out of park. I actually got it to come out of park a few times when I wiggled the cables but it still gets stuck in park.
