Question about Rainbow E series Canister Wet/Dry Vacuum
Have a Rainbow SE passed down from my Mom who bought it used.Never any trouble, haven't used it for couple of months. When I turn it on now , the motor hums, but doesn't suction. Was afraid to keep it running as I didn't know if the motor was locked or what. Can you advise if there is any home repair I might attempt?
  • 3 Answers
I believe the motor on this unit has brushes. These are little conductive pieces that provide electricity to the spinning motor windings. They wear out over time and need replacing.
I have found a link online that will show you how to disassemble, but it may not be the same model you have. Good luck.
Posted on Jan 16, 2011
  • richyoung Jan 16, 2011
    Sorry, the link is:http://www.thomaspenrose.com/diy_rainbow...
    BTW, this describes replacing the motor bearings, which could also be your problem.
  • 1,041 Answers
Steps to take before assuming the worst:
1. Make sure the latches on either side are locked.
2. You may have it too full of water. You should only fill it no more than 1/4" below the bulb in the center of the water container.
3. Make sure the Hepa filter is in good shape. If there is no air getting through it, than that may be the problem. If the filter is clogged, DO NOT run the vacuum! It will burn the motor up.
Jim
Posted on Oct 03, 2010
Will D4c se plug into D4c
The Rainbow D4, D4C and SE all are the same vacuum base, only changes were made to the nozzle. As long as the nozzle cord on your D4 has 2 prongs, not 3 prongs you can use the D4 nozzle that looks like This or the SE PE (SE Performance) Nozzle that looks This
Sep 01, 2014 | Rainbow Vacuums
How does Aqua Mate attach to Rainbow SE vacuum?
You can download the manual here...
Rainbow Vacuum Manuals
We are also available if needed at Contact Us
RainVac
Jun 18, 2014 | Rainbow E series Canister Wet/Dry Vacuum
SE rainbow vacuum break down photos
You are supposed to put water in those vacuums there should be a video on YouTube my mom had one like back in the 80s hope this helps Merry Christmas
Dec 09, 2017 | Vacuums
I bought my rainbow se vacum 4 years ago and I was using it and suddendly stoped working, I try to on no power I on and off not working at all. what shall i do is there posibility to work again.pls.help...
Hi, there is no reset button on a Rainbow vacuum.
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature. It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse. If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 13, 2010 | Rainbow 75th Anniversary Canister Vacuum
Rainbow SE vacuum cleaner has no power
Invert the vacuum cleaner without the water tray installed. With the machine unplugged, give the separator a spin clockwise. If it spins easily, this is a good sign. If the bearings are good on an SE, you should hear the faintest of rapid clicking sounds as you spin the motor. This is the sound of the brushes as the commutator segments pass under them. The brushes on SEs will sometimes hang up and not make proper contact; they are too precise a fit in their holders and the carbon dust they generate plus a tiny bit of moisture will cause them not to extend as they wear. When this happens, the brush tension spring overheats, relaxes, and it's time for new brushes and a service. Anyway, if you determine that the motor is turning smoothly (resistance or binding indicates bad bearings), install the water tray dry, plug the vac in, switch on, and give it a couple of bi__ch slaps with the palm of your hand on the side of the vac near the top. This can sometimes free up a stuck brush but the effect is likely not to last. It will, however, give indication of whether the machine might run or not after a fairly cheap repair (under 100 dollars).
Apr 04, 2009 | Rainbow 75th Anniversary Canister Vacuum
Rainbow SE makes Squealing Noise when switching it On/Off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
Rainbow SE makes Squealing Noise when switching it...
Posted by ray_s51 on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum.
The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
How do I remove the pin on my Rainbow Vacuum Model SE clips?
When I used to repair Rainbow SE vacuums for a living, I had a long nail of small diameter that I had filed the end off of just for this purpose. The pin you need to remove is grooved on each end to "catch" in the plastic housing, but a slight tap with a hammer, using this "nail" will do the trick. When you're ready to re-attach it, just tap it again to put it back in place.
Apr 04, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
233 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
