Question about SuperMicro X7DAE Motherboard
Systen over heat - SuperMicro X7DAE Motherboard
  • SuperMicro Master
  • 27,725 Answers
clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making VERY sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
hope this helps
Posted on Oct 03, 2010
2000 minivan emision control systen leak
Check the fuller nosily they sometimes rot and get little pin holes or the vapor line is rusty, this will cause them to leak vapor and trip your engine light giving you an emissions code, especially in the Dodge caravans VERY COMMON!
May 06, 2014 | 2000 Dodge Caravan
The central locking systen is draining my battery.
check for water ingress on the central locking unit
Jan 25, 2014 | Volvo XC90 Cars & Trucks
AX1300 will not turn on,got it to turn on briefly but what next?
Check that it is not over heating. make sure all fans are operational
enter the BIOS setup if it stays on while in the setup you may need to repair the operating systen with the install disk. Repair not clean install.
Jan 15, 2014 | Computers & Internet
My air conditioner on my 05 envoy will stop working,but it will work after awhile
check to see if the coolant fan comes on when u turn on the a/c...if it doesnt ur a/c system is over heating allowing the pressure in the system to build up to high...this will cause the system to shut down because the high pressure switch will shut off the system.. or if the system is low on charge it wont turn on until the engine heats up building up enough pressure in the systen for the low pressure switch to turn on the system..
Jul 14, 2011 | 2005 GMC Envoy
2001 gmc jimm running hot
You have air in the system, you will need to work that out, some engine have cooling systen bleeders, if not loosen a heater hose to bleed air from the system.
Mar 16, 2010 | 2001 GMC Jimmy
Charging systen failure light came on, lights dimmed for a min and so did heating system..what can this be?
this could be a bad altnator not charging the battery to keep the vehicle running and all the accessorys
Jan 02, 2010 | 2004 Pontiac Grand Prix
02PTCRUISER HEATING UP SLOWLY BUT WHEN STOPED HEATS FAST,FANS WORK ,THERMASTAT SEEMS TO WORK WATER TURNS, DOESNT HAVE ANY ANTIFREEZE IS THAT THE PROBLEM?
of course thats the problem. if you had a manual on the pt you will find that this is a pressurized system and just water without antifreeze changes the boiling point. Flush the systen and put the correct amount of antifreeze in, and replace the radiator cap with a 12-18lb cap.
Sep 30, 2009 | 2002 Chrysler PT Cruiser
SuperMicro X7DAE Motherboard Logo
66 people viewed this question
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
