Question about Garden
What type of blade do i need & how do i install it ?
  • b3charlie1 Oct 03, 2010
    I ASKED FOR A SCROLL SAW PROBLEM NOT A CHAIN SAW PROBLEM !!!!!!!!!!!!!!!!!!
  • 10,319 Answers
They are matched by the manufacture and model number when purchased
Posted on Oct 03, 2010
Uncut grass in center & higher grass cut on right.
Hi, this may sound obvious but make sure the new blade is the same type as the old one and make sure it is not fitted upside down. Spin the blades and make sure the tips are level with each other, this will tell you if the deck is straight where the blade spindles mount. Regards Phil.
Jun 24, 2012 | John Deere Garden
Need size to buy for wiper blade replacement for 1997 Ford Taurus sedan
Measure them & go to parts store for new ones
The store will do that & maybe install them for free
There are no more refills
You buy the whole blade & wiper
Sep 16, 2011 | Ford Taurus Cars & Trucks
I need directions on how to change the baldes on a reciprocating saw.
There are 2 types of clamps that hold the blade in that type of saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
Need to know how to put blade in
Just pull up on that rectangle shaped black piece on the top of the blade. Then pull the blade out. You can use both type blades in this model. take care and good luck.
Mar 08, 2011 | Skil 468004 5 Amp Jig Saw Kit with Laser
I tried to remove the blade with the method as described by Gavin, but I wasn't able to turn the blade by 90 degrees, so I'm not able to remove the old blade. What can I do now?
I don't know what type of saw you have or what Gavin suggested, but there are basically 2 types of locking mechanisms used by Bosch. One requires a long thi screwdriver and the other is a handle that you need to pull up on and loosen the clamp to remove/install blade. After loosening the clamp you might need to push up on the blade to rotate and remove. sometimes I have seen on this type there is a spring under the handle mechanism that breaks sometimes jamming the ability to release the blades. Let me know the exact model and type number and I will look at a breakdown and see what other ideas I can come up with.
Jan 08, 2011 | Bosch Saws
I need to adjust the wiper arm on a 1997 suburban, it hits the side of the window.
Wiper Arm & Blade (Front) Removal & Installation Wiper Blade To Remove:
  1. Turn ignition switch to ACCY position.
  2. Turn wiper switch to PULSE position and turn ignition OFF when wipers are stopped in the innerwipe position.
  3. Push the wiper blade clip button IN and remove wiper blade from wiper arm.
To Install:
  1. Insert wiper arm hook through opening in wiper blade.
  2. Place wiper blade pivot in the inside radius of wiper arm hook.
  3. Pull on wiper blade pivot into hook until it locks into place.
  4. Check wipers for proper operation.
Wiper Arm To Remove:
NOTE: Mark position of wiper blade on windshield to ensure proper position upon reassembly.
  1. Remove washer hose.
  2. Lift wiper arm from windshield and use a screwdriver to disengage retaining latch.
  3. Remove wiper arm from shaft.
To Install:
  1. Place wiper arm on shaft so that wiper arm aligns with marks placed on windshield.
  2. Press arm assembly on shaft and push retaining latch IN.
  3. Connect washer hose.
  4. Remove windshield markings and check wipers for proper operation.
Oct 26, 2010 | Chevrolet Suburban 1500 Cars & Trucks
What type fuse for THUMP! T1006 car amplifier
  1. Fuse Type - There are three main types of fuses used in car audio. The most common is the barrel (cylindrical) fuse which may be an AGC or AGU type. The second most common is the blade fuse which is the type most often found in your vehicle's fuse box. Large blade fuses are used in some fuse holders and may be referred to as a MAXI fuse. The least common type of fuse is the ANL or "wafer" fuse. These are used in the larger fuse holders when high current handling is required. Typically 100 amps and higher. The type you use will depend on the current capacity needed and your own preference. For draws of less than 100 amps expect to use a barrel fuse. For currents larger than that you'll probably be looking at the more expensive wafer fuse.
Dec 17, 2009 | Car Audio & Video
Need to change a turn signal & back brake
PLEASE DON'T FORGET TO RATE!!!
Rear Turn Signal, Brake, & Marker Lights
  1. Disconnect the negative battery cable.
  2. Open the trunk.
  3. Unfasten the nuts or other retainers from the rear trim.
  4. Unfasten or release the housing cover retainers.
  5. On some vehicles, you may have to remove the rear fascia/body panel and light assembly to get to the sockets.
On some vehicles, such as this 1986 Grand Am, you must remove the rear body panel with the lamp
Depending upon vehicle application, remove the lamp socket either by rotating it counterclockwise (approximately 1/4 turn) until the plastic tabs disengage, or by squeezing the metal tangs while pulling the socket from the light assembly
Remove the lamp socket assembly by turning it counterclockwise, then pulling it out
Generally, side marker lamps use small bulbs with flat, blade-type bases, and tail lights/turn signals use larger, round-based ("bayonet") bulbs.
  1. Remove the bulb from the socket using the appropriate method. Bulbs with blade-type bases pull straight out, while those with round bases and protruding pins (bayonet-type bulbs) must be depressed, then rotated counterclockwise (approximately 1/8 turn) before pulling out.
Remove the side marker bulb from its socket by pulling straight out
To install:
  1. Secure the bulb in the socket using the appropriate method. Bulbs with blade-type bases push straight in, while those with round bases and protruding pins (bayonet-type bulbs) must be inserted, then depressed and rotated clockwise (approximately 1/8 turn).
  2. Install the lamp socket using the appropriate method. Depending on the type of socket, either engage the plastic tabs, and rotate the socket clockwise (approximately 1/4 turn), or push on the socket until the metal tangs engage.
  3. Install the housing cover nuts.
  4. If removed, install the rear fascia and light assembly.
  5. Install the rear trim.
  6. Connect the negative battery cable, then check the operation of the rear lights.
Oct 17, 2009 | 1995 Buick Skylark
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
Can not get a blade on the Black & Decker Navigator SC500
Go to Dewaltservicenet.com and in the middle of the page at the bottom find the looking for manual box type in your model number and on the next page click on the instruction manual section for this tool, it is 4 pages long but it does reference removal and installation of the blade. If I have answered your problem would you please rate my response accordingly and thank you.
May 17, 2009 | Black & Decker 11-3/4" Navigator General...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
