Question about Garden
Remove motar from whisper flo pump - Garden
  • johnv916 Oct 03, 2010
    I have a three quarter horse moter on a wisper flo pump the motar is a.o. smith i have the motar and impeller off the housing took the screw out of the center of the shaft and i dont want to break anything how does it come off
    thanks
  • 857 Answers
Replacing your pool pump motor
Gather the following items.
Phillips and flat head screwdrivers
Circuit tester
Dry towel
Step One
First, make sure that the power to the pump is turned OFF. This means turning off the breaker at the panel box and not just the switch at the pump.
Step Two - Removing the motor assembly
Remove the four hex head bolts which hold the motor assembly to the pump/strainer housing (These bolts may not be visible).
Slide the motor assembly out of the pump/strainer housing, exposing the diffuser. Pull the diffuser of of the seal plate, exposing the impeller. (The diffuser may remain in the pump/strainer housing. To remove, pull it straight out of the strainer housing.)
There will be a gasket or O-ring sealing between the motor mounting bracket and the strainer housing. Inspect this thoroughly and replace if necessary. An economical option would be to purchase a Go-Kit which includes the pump shaft seal and all necessary o-rings, gaskets and lubricant for your pump.
Step Three
Now, you can lift up the motor with bracket attached to get to the wiring more easily. There may be a bare copper ground wire attached to the outside of the motor that you will need to disconnect. Remove the cover plate on the back of the motor to get access to the wiring. You should have one green wire that is the ground wire and two other wires that are your leads. The lead wires should be black and white but could be any other color except green. Disconnect these wires (they may be attached to a screw, held down by a nut, or clipped on with a terminal clip).
Step Four
Next, you will need to disconnect the conduit (sleeve covering wires between motor and switch or junction box). This usually means unscrewing the compression nut that is screwed on the adaptor which is screwed to the motor. After unscrewing the conduit compression nut, you can pull out the wires from the motor. If you wish to reuse the adaptor, unscrew it from the motor.
Step Five
Now you must remove the impeller from the motor. Remove the volute covering the impeller if it is there. (Some are screwed on). You will need to go to the opposite end of the motor and pop off the plate covering the shaft. The shaft will either have a slot in it for a screw driver or is flattened to allow you to put an open end box wrench on it. This will allow you to unscrew the impeller. You will unscrew in the direction that is opposite to the direction that the veins point at the outside of the impeller. This is the same direction that the motor will rotate the impeller. This may look backwards but the water comes into the center of the impeller and rolls off the veins away from the impeller by centrifugal force. As you take the impeller off, be sure to note how the pump seal is positioned. We highly recommend replacing the pump seal with the purchase of a Go-Kit when replacing the motor.
Step Six
Now you can see the bolts that hold the motor mounting bracket to the motor. Unbolt these, separating the motor mounting bracket from the motor. You are ready to reverse the process to install the new motor.
Step Seven
Important Notes on Reassembly: DO NOT touch the ceramic faces of the seal; This may cause the seal to burn up and leak. Be sure to tighten the impeller completely. Be sure to wire the new motor for 110V or 220V depending on what you have. This may be a simple switch in the motor or you may need to use the wiring diagram on the motor to set for the proper voltage. (Black tracer means the white wire with a black line corkscrewing around it.) Be sure to put the volute back on, aligning properly. Be sure to reconnect the bare copper ground wire to the ground lug on the new motor. When tightening bolts, alternate tightening a few turns at a time to seat evenly or the pump may leak. Fill the strainer housing with water before starting the motor to prime system and prevent damage to seal and impeller.
More Helpful information on how to replace a pool motor
Shaft Seal installation
Clean and lubricate the impeller hub shaft and pump housing seal recess with a dilute solution of non-granulated liquid-type soap
Gently wipe the black, polished surface of the spring seal assembly with a clean, soft cotton cloth. Press the spring seal assembly onto the impeller hub with black polished surface facing away from impeller.
Gently wipe the polished face of the ceramic seat with a soft cotton cloth. Lubricate the O-ring on the ceramic seat and press it firmly and evenly into the recess of the seal plate with polished side facing out.
Place the seal plate onto the motor mounting bracket aligning the positioning lug and guide.
Replacing the impeller and diffuser
Slide the motor assembly, with the diffuser in place, into pump/strainer housing, being careful not to dislodge the diffuser.
Fasten assembly to housing using the four bolts. (Be sure housing gasket is in place.) Tighten alternately and evenly
Posted on Oct 03, 2010
  • Jayant Jha Oct 03, 2010
Removing the lid from a hayward power-flo matrix
Too Much Pressure????
Are you trying to remove lid when the pump is on? NO, NO, NO
If not, then good! If you have valves before and after the equipment, then close them. Then remove the small 1/4" drain plug to empty the pot. Then try removing the lock ring and open it up.
Jul 13, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
I have an older pool, and it has a purex triton whisper flo pool pump and don't know how to back wash. I am not seeing anything that says backwask or a lever to turn. I need to back wash because my...
You can not backwash a catridge filter. If cleaning them doesn't work they need to be replaced. A common 'issue' with cartridge filters - replacing the expensive elements every few years. There is no other way to clean them that will not in turn destroy the filter material in the process so new ones are your only choice.
John
Jan 14, 2011 | Pentair Plumbing
When my spa is on heat mode pump on Low Speed it will not heat up. It says FLO and flashes do I have an air lock ??? Just changed pump a month ago.
FLO is a common signal for insufficient water flow through the heater tube. Do you see the low speed pump working? If you do, then try removing your filters, if FLO goes away then replace your filters with new ones. If not, your flow switch may not be working. You could have a legitimate flow issue caused from a clog or air-lock though.
Dec 17, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Pump needs to be reprogramed
Whisper flo pumps do not have a computer to program. If it is an INTELLIFLO you would need to program. The programming manual can be found at PENTAIRPOOL.com
Sep 08, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Removal of Aqua-Flo pump from motor
You will need to pull the front of the pump off then unscrew the impeller. The impeller will be set on the shaft and will take some force to break free. Hold ing the back of the shaft and using water pump pliers on the face of the impeller will usually work but sometimes I will wedge a screwdriver in the fin of the impeller and hit it sharply (not hard) with a hammer to break it free. Then the housing will just pull free of the motor. When replaceing, the impeller just goes on hand tight. Hope this helps and good luck.
Apr 15, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
LF READING ON PANEL
LF means "Low Flow". Remove the filters to see if the code goes away. If not, the pressure switch may be bad.
Feb 09, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
Whisper Flo model WFE 6 (1 1/2 HP) appears not to turn thus not pumping water through system; only clicks on/off when pressing fitler motor button on panel. Other spa equipment consists of: Pentair...
Possible bad motor. You would need to test voltage at the motor connections with a multi meter. If the voltage is correct, then the motor or start capacitor is bad. If the proper voltage is not correct, then you would need to look upline in the electrical system to find the problem
Oct 25, 2009 | Pool & Spa
REMOVE WET END FROM MOTOR ON FLO-MASTER XP2
You will need to remove the six bolts/nuts on the wet end to expose the impeller. At the rear of the motor, remove the cap covering the shaft and restrain the shaft and spin the impeller off (counter-clockwise). Check to see if there is a screw in the center of the impeller and remove it by turning clockwise (if applicable). Once the impeller is off, you can remove the four through bolts from the rear of the motor using a 5/16 nut driver and the wet end should come right off.
Oct 18, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
How do I get to the pump seal on my hi-flo water
The impeller threads off the shaft and most likely is right hand threads. You will have to lock or hold the motor to remove the impeller. If you remove the motor cover you might find that the motor has a slot in the end of the shaft or two flat sides so you can hold it with a flat wrench.
The impeller is probably plastic and could break. Get a strap wrench to remove the impellor.
Sep 20, 2009 | Waterway 1.5hp Hi Flo Above Ground Pool...
SEal replacement on Flo-Master 1 hp 2 speed pump? Tough to remove. Any tips on removal?
Pump seal is in two pieces. The piece with the spring should be easy to remove. To remove the piece that is inside the motor side of the pump housing, place the housing with the side that should be facing the motor downdwards on a flat surface. The hole in the housing is larger than the seal, so use a screwdriver and, placing first on one side of the seal and then the other, strive the handle of the screwdriver sharply and the seal should pop out the bottom. The seal is rubber, with a ceramic insert, so if you don't tap the screwdriver too sharply the insert won't be damaged. In any case, it's a good idea to replace the entire seal if you have had to open the pump and remove the impeller
May 23, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Garden Logo
136 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
