Question about Radio Communications
I have uniden cb and I can't get the pa to work it just play the weather and my antenna is broken if it has anything to do with it
    Genius:
  • 1,274 Answers
Hi, my name is John. Some twenty-three channel radios have the PA located between channel twenty-two (22) and channel twenty three (23). Make sure you have the right PA plug for it, as far as the antenna, get you a good one, say a Wilson 1000 or a Wilson 2000, they are great antennas, magnet mount. You need to press the PA button. Hope this was helpful...Rate this solution on the four thumbs-up. .Good luck John.
Posted on Oct 07, 2010
Uniden 40-Channel CB Radio (PRO505XL) "PA" acts like an extra external speaker!
because when you switch to PA it is because you are on the outside of your vehicle.When another party calls you ,you can hear them and then go to your vehicle flip it to cb and talk to your party.
Jul 07, 2014 | Uniden Pro505xl 40 Channel Cb Radio
Pa speaker has cb channel playing on it not my voice
do you have speakers hookd into both the ext and pa connectors in the back of the the radio? If not try it , it should work.
Apr 18, 2014 | Uniden Bearcat 880 CB Radio with 7 Color...
Pa problems
look on the back of the radio. See those two holes that you can plug a speaker into, well one is for CB the other if for PA. plug your Pa speaker into the appropriate connector and you have Pa capeablity. You must turn the switch to pa on front of radio.
Mar 24, 2014 | Cobra 18 Ultra Weather Band Cb Radio 40...
Uniden 520xl won't turn on. Hooked up correct and tested cont. but still won't work?
Is your CB/PA Switch set to CB? It's common for folks to forget to make sure the switch is set for CB and not PA (Public Address Loud speaker Function).
Feb 19, 2014 | Uniden Radio Communications
My cb wont pick up anything.
The coax on the lil will may be bad. Do you have a swr meter? If not get one and make shure its not the lil will. If you need work done www.herzjoe3@gmail.com. I have 15 yrs in cb's
Jun 24, 2012 | Uniden Bearcat Pro PC68XL 40-Channels Base...
My cb radio is on but cant hear nothing sound is turn up but nothing come out
You didn't include the make / model CB you have, so I can only offer general suggestions. If these do not work, please provided the missing info.
Start out by locating and setting the the Volume to a position between 1/4 and 1/2 way clockwise, the Squelch to fully counter-clockwise and the "RF Gain" to fully clockwise to "MAX".
Check the position of the "PA / CB" switch and set to CB. When set to PA, both receive and transmit audio is sent directly to an outdoor speaker (instead of through the transmitter and antenna for reception by other radios). The PA speaker is usually connected to a jack at the rear of the radio. When the PA / CB switch is selected, the internal speaker is silenced even if there is no PA speaker connected.
At this point, you should hear static or voices (with an antenna connected). Do not attempt to transmit without a properly tuned antenna connected. If no sound is heard, there's something else wrong.
May 22, 2012 | Uniden Pc 78xl Cb Radio Mobile
I have a Uniden 525 fixed mount 2-way VHF radio. It has power and picks up weather with the shakespeare antenna. However radio checks have failed and i don't receive anything either. The antenna's tip is...
Yes if the tip is broken, the antenna will receive, but not transmit properly. The make an antenna that has a 32" stainless steel antenna with a small metal "can". Can mount it anywhere.
Mar 28, 2011 | Uniden UM525 ES Series VHF Radio with...
The power/volume knob doesn't do anything. Whenever power is given to the radio, it's always on. No sending or receiving on any channel. Also, whenever the weather knob is turned to anything but 0, that's...
I have a uniden pc79 I have been working on with a similar problem. Its basically the same radio as the one you have.
Far as I can find so far it is a problem with the weather board, and how it is interrogated into the radio.
The way the do it now, the weather board is part of the radio now, so it will not function without it.
Some one I know told me it could be a problem with the VCO as well. If it is not aligned properly. I have not had a chance to try aligning it yet.
Pretty much there is something blown inside the radio. I wish I could tell you what. Never the less, the radio is going to need either a tech, or to be sent back to cobra.
Mar 29, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I can only get the weather channel but the cb side dosen't work what do you think it can be?
You don't give me much to work with. Is the weather selector switch in the CB position? Do you have an antenna hooked up? Have you checked the SWR on the antenna? What power reading do you get when you key the mike?
Please give me some feed back.
Jun 26, 2009 | Uniden PC68LTW 2-Way Radio
I can't pick up anything...
Hello even though everything is connected properly, have you checked for standing waves on the antenna to radio connection? Also you may have to perform a sensitivity test on the unit. The problem is you need a RF generator for that. Set you RF generator to the frequency that is equal to the CBs middle frequency and modulate the CW with 1KHz at 50% modulation, tune to the middle of the CB band on the radio and set the output of the RF generator to .1uv and loosely couple the signal to the CB antenna with a loop of wire. Your CB should be picking up a 1KHz tone gradually turn the power level down and when the tone cuts off that level is cutoff level, then increase the level until you can hear the tone again when the tone cuts on that value is the sensitivity of the unit. Compare the measured value to the value in the owners documentation. if the sensitivity is low this could denot a problem in the RF/IF section of the CB.
Oct 04, 2007 | Uniden Bearcat Pro PC68LTW 40-Channels...
Radio Communications Logo
65 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
