Question about GE Spacemaker JVM1640SJ Microwave Oven
Wife burned food
After checking house breaker and fuse behind vent cover microwave still dead can you advise. GE space maker jvm1653sf001
  • GE Master
  • 9,047 Answers
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout / thermal fuse on or near the magnetron or the one on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 30, 2008
Went to warm up a food item and after 3 seconds the microwave shut off like the circuit breaker tripped. time face went blank, light inside does not light up and stove top lights do not light. circuit...
You have a fuse behind the screen panel. You have screws inside the microwave holding the panel. you have 1-2 at the bottom. You may also have to remove the vent. It has 2-3 screws which will be inside the vent. These can be removed from the front. Once these are removed the panel will pop off and you will see the fuse The fuse can be bought at a radio shack. BE SURE TO UNPLUG THE MICROWAVE! Good Luck
Dec 04, 2010 | GE JVM1631 Microwave Oven
GE Advantium 120 oven: Was boiling water and oven completely powered off. House circuit breaker is OK and not tripped. Plugged into another working outlet with extension cord to see if display came on. It...
You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
Feb 05, 2010 | GE Advantium 120 Convection/Microwave Oven
Ge advantium 120 microwave oven completely dead
You have a bad cavity switch. I would guess it is the one behind the vent cover, toward the left side of unit. You would need to remove unit from wall. Remove outer housing to expose cavity switch. You can see it from vent cover, I would test all cavity switches before removing from wall. You should have a diagram of unit folded up behind vent cover towards right side of unit. This tells all workings of unit. Will also tell where all cavity switches are.
Dec 30, 2009 | GE Advantium 120 Convection/Microwave Oven
Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Mouse in vent fan?
Yes, the mouse was probably attracted to the warmth and food odors in the duct work and may have gotten trapped in the vanes of the fan and died. I'd act fast...
The best bet is to remove the oven from the wall, or almost from the wall, so you can see the area of the hood vent exhaust fan.
This is safer with two people and the installation instructions will be of great help.
You can download GE owner's manuals and installation instructions here.
Dec 09, 2008 | GE Advantium 120 Convection/Microwave Oven
GE JVM2070 issue
what is the make and model number
Mar 26, 2008 | GE JVM2070 Microwave Oven
Microwave won't come on
I am a recently retired appliance engineer of 20 years, i am reluctant to help with microwaves because of the dangers, the store electric even when unplugged, but it sound just like an internal fuse, these are special quick blow types, can be bought from most electronic high store shops, and replacements must be exact match, if a replacement blows there is another fault and don't recommend self repair work with safety and remove the plug first etc oh the fuse is just inside following the mains wire in, and normally on a small circuit board if i have helped please rate me
Sep 09, 2007 | GE JVM2050 Microwave Oven
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Jul 25, 2007 | GE JVM2070 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
83 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
