Question about LG DLE2514 Electric Dryer
Dryer makes loud humming noise but drum doesn't turn when I push start.
  • 489 Answers
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Posted on Oct 04, 2010
Whirlpool dryer was making loud squeaking noise. Now it is not turning at all. Makes a noise when you turn it on, but stops completely.
Check the drum belt. Check the drum rollers on the back & glides on the front that the drum rides on also check the idler pully. Check the felt the drum rides on in case it came loose and won't let the drum turn. Did it hum when you started it if so could be the motor. Good luck
Apr 06, 2014 | Whirlpool GGW9200L Gas Dryer
KEYS750LQ0 dryer doesn't start it just hums when I push start
Check the belt. You may have to open the machine up to look. if the belt is ok turn the drum by hand and see if the motor pulley is also turning. While you are in there look for foreign objects that have wedged against the drum preventing it from turning.
Oct 09, 2012 | KitchenAid KEYS850LQ Electric Dryer
My Maytag MDE9606AYW drum randomly decides to not start. I hit the push button and there is loud noise but the drum doesn't move. When it does start the loud noise happens but it is quickly replaced by...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 02, 2011 | Maytag MDE5806AY Electric Dryer
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
heatman101
Sep 25, 2010 | Maytag Dryers
My whirlpool ler4634 electric dryer has electricity running to it but when turned on, the drum does not rotate. It only makes a loud humming noise. What can be the problem?
It sounds like you have a blown motot try holding down the door switch and push start and turn drum at same time see if it kicks in
Sep 22, 2010 | Whirlpool LER4634J Electric Dryer
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
LG DLE2514 Electric Dryer Logo
1,060 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
