Question about Columbia Telecommunications Group 2.4GHz Cordless Phone with Answering Machine (cta-400)
Where is the on-off button on my Personal Digital Assistant (PDA) model # PD-210
Jandy PD a is stuck on waiting mode
try turning aqualink off and PDA make sure batteries good turn on aqualink after boots then try PDa if no good check wire to antenna
Apr 30, 2018 | Jandy Pool & Spa
Tried to open a can instead of a jar in my jar opener by mistake and now it is stuck
Sorry? Can you clarify your problem, is this about a pda? Personal data assistant its a small computer you hold in your hand?
Nov 01, 2008 | Computers & Internet
How to activite bluetooth in windows 7
  1. Add a Bluetooth adapter to your computer.
    This is usually done by plugging the adapter into a USB port. (If a Bluetooth adapter is already built in or attached to your computer, ignore this step.)
  2. Set up the device so that your computer can find it.
    To do this, you must:
    • Turn the device on.
    • Make it discoverable.
    To learn how to make a device discoverable, check the information that came with your device or go to the manufacturer's website.
  3. Install the device.
    To install most devices, such as a mobile phone, keyboard, mouse, or personal digital assistant (PDA), you can use Bluetooth Devices in Control Panel. If you have Bluetooth wireless technology installed on your computer, follow these steps:
    To install a Bluetooth enabled device
    1. Click the Start button , click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
    2. Click Add, and then follow the instructions.
May 30, 2011 | Computers & Internet
What is PDA
It stands for "Personnel Data Assistant"
Jan 20, 2011 | Computers & Internet
Need manual for pda pool digital assistant
go to jandy website they have them on there website
Nov 24, 2010 | Jandy Aqualink Pda Ps4 Wireless Handheld...
I have a PD-210 Personal Digital Assistant. It's been years since I messed with it. I just put fresh batteries in and I can't figure out how to update the time & date......and I can't get it to link up...
It is very possible that the PDA has become obsolete through the lack of updates which are necessary to keep the unit operating along with todays operating systems.
Mar 28, 2010 | Computers & Internet
I don't know what to choose. an e63 0r a samsung omnia pro b7320. Does the gps work in the samsung, and what about the battery, does it last that long. please help
Hello. I definitely recommend the Omnia Pro which is a full PDA phone. In my opinion the e63 is gimmicky. A PDA Short for personal digital assistant, a handheld device that combines computing, telephone/fax, Internet andnetworking features. A typical PDA can function as a cellular phone, fax sender, Web browser and personal organizer. Regards, Joe
PS kindly rate my answer as helpful. thank you.
Feb 14, 2010 | Samsung Omnia Pro B7320 Smartphone
I have a dell optiplex gx620 and it wont turn on all it does is the power button flashes orange.
As you can imagine, this is not simple thing to diagnose.
First, we need to try Dell's steps to fix...
Remove non-essential peripherals…
Except for the monitor, keyboard, and mouse, remove all external peripherals including:
  • Scanner
  • Printer
  • Modem or Network cables
  • Personal Digital Assistant (PDA)
  • USB flash drive or other external Hard Drive
  • Any other external devices (e.g., USB-attached devices)
  • Remove the computer from the docking station, if you are using one
  • Scanner
  • Printer
Try rebooting. If that doesn’t work, Dell states you need to do the next step.
Remove and Reseat Basic Hardware items:
  1. Power Cord
  2. Memory
  3. Hard Drive
At this point, Dells says if that fails contact them.
If my hunch is correct, you may have something on the motherboard shorting a connection or you have a blown capacitor. Get some “canned air” and blow out the computer thoroughly. Some people have reported the same symptom having dust or other debris causing the issue, so give it a good blowing out,
At the same time, inspect your motherboard thoroughly for an anomalies. If you see anything resembling the picture below, you have a serious motherboard problem which will require replacement.
Oct 20, 2009 | Dell OptiPlex GX620 PC Desktop
Memory on HP ipaq 114.
there are two types of memory my friend
1. RAM
2. ROM both built in PDA
third type is Storage Card u can store music and photos there but u cannot merge it with RAM or ROM so pls try to understand this difference
secondly if u want me to help u out on this memory shortage
then u can reset the device i mean hard reset and re install ur applications by time ur ROM is occupied by some useless files and ur performance is de graded try to refresh ur OS
Hard reset
HP iPAQ Setup Assistant
Use HP iPAQ Setup Assistant to simplify configuring settings on your HP iPAQ.
HP iPAQ Setup Assistant lets you save the settings on your computer. This can help you restore configuration settings on your HP iPAQ at any time. HP iPAQ Setup Assistant also allows you to perform a factory reset on your HP iPAQ and view detailed product information.
To hard reset HP iPAQ 114:
- press and hold the 3 buttons Windows, OK and REC
- press the reset button for about 3-4 seconds and release it
- release the 3 buttons
u can see the video for that but it is in russian lang but self explanatory
http://www.youtube.com/watch?v=BG68AzNBsds
third option is if u want to really get rid of this slow performance and shortage of space just get a clean CUSTOM ROM from
http://forum.xda-developers.com/ for ur PDA strictly at ur OWN RISK
pls rate me fixya if i have fixed ur problem
Mar 01, 2009 | HP Computers & Internet
Sync calander with PCs and PDA
As you stated, sharing your Outlook Personal Folders file (.PST) is not supported by Microsoft.
However, there are other companies that make products that support sharing your PST.
Here is one:
http://www.officecalendar.com/slipstickshare.aspx
BTW: http://www.slipstick.com/index.htm is a great resource for finding Exchange/Outlook solutions.
Before experimenting I highly recommend that you close Outlook and make a copy of your .PST just in case you encounter problems.
I hope this helps.
Dec 02, 2008 | Software Pursuit SureSync 4 Workstation...
Columbia Telecommunications Group 2.4GHz Cordless Phone with Answering Machine (cta-400) Logo
57 people viewed this question
Top Columbia Telecommunications Group Lands Phones Experts
David Burbee
David Burbee
Are you a Columbia Telecommunications Group Lands Phone Expert? Answer questions, earn points and help others
