Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Internal flex suction hose is leaking
The internal flex hose (not the extension hose is cracked and leaking from too many flexes I guess. Can I repair it myself? Dealer is too far away. No insttruction in owners manual.
Tom Millen
  • 1 more comment
  • Janetoms May 26, 2008
    I am a retired mehancal engineer who never lkes to throw anything away unless i find out why it failed or fiix it.
  • Stormi May 24, 2013
    Mine did the same thing and I am still looking for a replacement hose, until then there is this tape thats like rubber. I started from the hose about a inch or two above the split worked my way down on top of where it connects. I did it in the open position since thats when the tension is on the hose. I'm just mindful when I engage the suction and release the handle to do it not so rambunctious. I need things built out of rubber, I'm brutal on all my appliances. Hope this helps. this is the tape I picked uphttp://www.rescuetape.com/
  • Anonymous Mar 14, 2014
    The flex on my steam grime master is now very long and therefore I cannot reach the places where I would like to use it as my household plugs are too far away from the areas i.e. shower area and windows that I would like to use it on.
    President:
  • 1,673 Answers
The hose where it hooks to the motor unit usually splits there, if this what you are talking about, then you can replace the hose asm. Part # H-90001336
You can go to http://vacuumsuperstore.com/
and order it thru them, or call a local service shop.
$36.00 tableWorkaround2(1)
Posted on Jun 01, 2008
Motor blows - no suction - no hoses blocked - air is coming out of hepa filter hole - where is the air coming in?
If you turn the suction valve to tools and block the hose you should have no air coming out of the filter. If you do it may be a bad diverter valve. Another possibility is a leak in the system. You can also do the same thing with the hose inside the rug nozzle. If they were both sealed off that would confirm an internal leak.such as a motor gasket failure.
Jun 28, 2015 | Eureka Smartvac 4870 Bagged Upright Vacuum
The hose suction on my Dyson Animal (DC41) is fine, but will not disengage when you put the hose back and want to use the floor sweeper.
Hi Stacy, it's Jack at Dyson.
This issue you've described with your DC41 sounds unusual, as the changeover valve will divert suction to the cleaner head automatically when you recline the machine into the vacuuming position. If it's not doing this, it's possible you have a blockage somewhere in the cleaner head, internal hose or changeover valve.
To check for this, please follow the steps shown in our online Support guide: http://www.dyson.com/support/dc41/dc41-irspu/diagnosis-root-menu/performance-flo-area-check-dc41/flo-brushbarvid-dc41/redirect-to-performance-flo-base-dc41-checking-the-internal-hose/performance-flo-base-dc41-checking-the-internal-hose
If you'd like some further advice after you've given us a try, please email our experts with your details at askdysonUS@dyson.com. Someone will be in touch to help as soon as possible
Feb 27, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
My prolux will not **** up dirt
Check the flex hose between the power head and body of the vacuum. If it's cracked, which is likely, there will be a substantial loss of suction at the brush area.
To remove, simply lay the prolux on it's side, pull out the end connected to the power head, then unscrew the end connected to the tank. Turn in a clockwise motion to do so.
To install new hose, screw into the tank in a counter-clockwise direction. When firmly in place, gently push other end into the power head. Manipulate it so it is all the way in.
Happy New Year!
Jan 01, 2011 | Electrolux Vacuums
Suction is low, but bucket is not full and filter is relatively clean
The filter may be relatively clean, but if there's a lot of fined dust in your area the pores of the filter will fill and clog fairly quickly. Try replacing the filter and see what happens. If you don't have a spare, consider purchasing one for use while the other is drying out. Then alternate.
A leaky hose could also cause a loss of suction, as could a broke or cracked flex tube (the short piece in the power head).
Aug 05, 2010 | Electrolux Central Vacuum
Vacuum not picking up much but the hose attachment has no problem
I assume you've checked for blockages and that there's a useful length of bristles on the brush roll. Turn the machine over, and just behind the brush you will see a short length of clear plastic tubing with spiral reinforcing. That tube often splits, so there's an air leak and consequent loss of suction at the brush. A split may not be immediately obvious - to get the tube off, pull it off from the motor end and then unscrew it at the brush end. As a temporary measure you can cover a split with tape, but the tube undergoes so much flexing that tape is rarely effective for very long. A new hose (it's called the internal hose) is not expensive and is the only permanent solution.
If the internal hose is not split, post a reply here and we'll see what else we can think of. Good luck!
Jun 05, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Henry keeps shorting out? Changed fuse and bag but still wont work?
Most common cause of this problem is a damaged flex. Damage may not be visible externally, but after a lot of bending and pulling the wire inside the flex can break. This usually happens close to the plug, so examine it very carefully for signs of damage (if there has actually been a short circuit, there may be a tiny hole blown in the outer insulation). Unfortunately there is no easy way to locate an internal break without special testing equipment. You can try just cutting off the old plug with about 6 inches of flex, and then fitting a new plug - if that doesn't work you may need professional help. Good luck!
Feb 28, 2010 | Numatic Henry Bagged Canister Vacuum
My Sebo X4 does not power up, it worked fine the day before but now there's no power. What could be the problem?
Most likely is a break in the electric flex. This can be internal, and completely invisible from the outside. Alternatively, the cable may be visibly damaged so check it carefully. Internal damage usually occurs at the extremities of the flex, where it leaves the plug or where it enters the machine, it's hard to detect without suitable testing equipment, although simply moving the flex around (with power switched on) will sometimes locate the problem. Depending on your wish or ability to deal with this yourself, there are several solutions. Of course, if the fault is at the plug end, the old plug can be cut off and a new one fitted. If the fault is at the machine end, the handle can be re-wired but the usual solution is to fit a new handle (complete with flex). This is more expensive in material terms but works out cheaper than a re-wire when labour costs are added (there's no labour in fitting a new handle, but re-wiring a handle takes time). If this doesn't help, please post a further comment, indicating how confident you feel about taking the machine apart, and we'll consider other options. Good luck!
Dec 14, 2009 | Sebo X4 Bagged Upright Vacuum
Hello! The suction in my Dyson animal is very poor. I discovered small holes in the internal hose, but even after a quick duct tape fix, still having issues...sounds like the seal from the canister to the...
Hi there SmartAlec from NelsonVacuums.com.au here. If your only going to use it once you can remove the washable filter it is likely choking the suction off and is in need of replacement. If this improves the suction you can purchase a replacement dyson filter here. Hope this helps. Happy Vacuuming :)
Oct 26, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction when I vaccum the floor but not in the hose
remove the filter from the dirt cup and try again,if you have suction the the filter is clogged.the other is the intake hose that goes into the top of the base where the clear tube is.disconnect the hose from the base tube and take a coat hanger and bend the end into a hook.open the litte flapper door and stick the hanger down in the tube and see if you can pull out a clog of dirt.last but not least,disconnect the top hose completelyfrom the vacuum and see if you can blow through it.if you can't then the flex top hose is clogged.open the little flapper door on the top of the base and turn on the vacuum,if the intake hose isn't clogged then you should have suction.that will tell you that the broblem is in the flex hose or the filter
Jun 07, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Broken Nutone central vacuum unit
most of those systems are plumbed with PVC, but some do use flex throughout the home...
If yours is PVC, visit your nutone dealer and get a new outlet/elbow.
Trim the old elbow off with a drywall saw or other small saw (if you have a sawsall, that is fine) and glue the new one in
if it is flex tubing, it's easier; the elbow threads on. just be sure to hold the tubing so it doesn't drop down,
Jan 02, 2009 | Broan-NuTone CV353 Central Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
179 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
