Question about Sony Playstation 3 (PS3) Console
I had a power outage while playing a game and when power was returned the playstation3 system came back on. Afterwards a screen apeared saying to restart the system before continuing, but before I did I checked everything as far as system settings and photos etc. to make sure nothing was damaged. After about 5 minutes the screen went from operating normally to turning off and having the system beep 3 times. Now everytime I try to turn on the system it sounds like it wants to start up and the fans and all start to work then after 2 or 3 seconds it shuts off and the red light on the front goes from red to white and the system beeps 3 times .
  • 644 Answers
It is possible that the power outage has damaged your power supply, but there is a way of checking this. Unplug from the mains leave it for a minute, the switch at the back of the ps3 turn to the off position, plug back into the mains, turn the back switch to on to off then on and see if the console will power up, if not, and you have no warrenty left you will have to open up the ps3 there are guides on how to do this on youtube just have a search and you will find quit a few good videos, unplug again from the mains, take the top cover off, looking from the front of the ps3 on the left you will have a rubber insert, with a sticker on it, take out the rubber insert, inside there is one screw you will need a star ended srewdriver, somtimes a small alan key may do it, once undone and out put a bit of pressure on the top and slide it towards the left in should just slide and pull off, you then need a philipes or pozy drive screw driver to undo the 6-8 screws on the top of the inner housing, once they are all undone, from the back pull up and towards the front of the ps3 and it should come away, becareful not to snap the plastic clips.
There you will see the hardrive on the left and the blue-ray drive on the right, you will be taking out the harddrive there will be four screws holding in place, undo these and unplug the wires from the hdd and pull upwards it might be a bit hard because it plugs in the board with 2 prongs make sure you are careful not to go to rough it will come off, once the harddrive is out set the switch at the back to the off position and plug back into the mains, turn on by the switch at the back, what you are doing here is a hard resset once done that and the ps3 is unplugged again from the mains you can put it back together again, you same way you took it apart, make sure the screws for the inner caseing go into the right holes there will be a slightly shorter screw, make sure this one goes back into the right hand back corner, the others are all the same length so no need to worry about them, once back together plug the mains back in and power on from the back and see if it will boot, if you still have the same problem then it is likely that you will need a new power supply. hope this helps and post back what happens thanks.
Posted on Oct 03, 2010
Playstation3 problems
You might have to do a system restore. I don't know why playing a game would do that, but it happens. Here is a vid that will help.
PS3 FIX The file system on the system storage is corrupted REVIEW
Apr 07, 2014 | Video Game Consoles & Games
PLAYSTATION3 TURNS ON ,AFTER ABOUT 1MIN. TV SCREEN SAYS HOT ,
Ok sounds to be ur fan not working,,or clogged,,ok check the system vents,,if dust in there,,blow out with air in a can,,if anything aircompresser,,with blow tip,,or u blow in it,,could fix it,,,try and see,,if not see if u hear ur ps3 fan running,,,could be bad,,easy fix,,,good luck
Feb 09, 2013 | Sony Playstation 3 (PS3) Console
I hooked my PS3 to my HDMI cable to get a better visual screen display for my HD movies and games, but display screen went blank and I cant get the commands menu screen, how can I get the menu commands...
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Jun 16, 2012 | Video Game Consoles & Games
    My play playstation3 says it was not switched of prpoperly
    remember to always turn off the system with the use of the on screen shut down before turning of the switch on the back. if you continue to do whats called a hard shutdown like that you could end up destroying your system
    Jan 04, 2011 | Sony Playstation 3 (PS3) Console
    I have a new Sony HDMI LCD tv and a PS3 game system. I am having trouble playing Dead Rising 2 in 1080i mode. It will only play in 720 p mode, even though I changed the setting to 1080i on the...
    Some hd tvs do that,,its not u,,try in ps3 settings turn only 1080i setting on,,only,,same on tv also,,if not try with evryone of them selected,,let hdmi cable do it automatic
    Nov 04, 2010 | Video Game Consoles & Games
    Can't play any games.
    Hi!if the problem is recurring with other games then you will have to call Sony as it looks like a hardware error mostly in the lens mechanism..do u get an error code?i had the same problem and had to get the lens replaced..if your console is under warranty do call Sony..al details will be on the playstation3 site..hope it helps!
    Nov 26, 2008 | Sony Playstation 3 (PS3) Console
    Playstation3 drive dont seem to be working
    Bluray laser is dead!
    sent to Sony for repair under warranty(luckily)
    they sent to Mexico for cheap repair.
    still waiting for return
    Nov 15, 2008 | Sony Playstation 3 (PS3) Console
    The starup screen is not going to the main menu
    Try this:
    Hard Reset procedure for the PS3 (as instructed by Sony CS).
    Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
    1. Power Off the PS3 via the power switch in back and power back on w/switch.
    2. Hold Power Button on the Front until you hear 3 beeps.
    3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
    4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
    Hopefully this will solve your freezing problems.
    May 11, 2008 | Sony Playstation 3 (PS3) Console
    Playstation3 not working
    Please post any solution that you may hear of. I have spoken to Sony and searched many forums and have come up with nothing. Except that one guy claimed he had this problem and when he installed linux his machine was able to use the drive thru linux.
    Dec 03, 2007 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    129 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
