Question about RIM BlackBerry Pearl 8100
Cant see start menu button
1. Cannot see the start menu button. Seems to be stuck Today Screen. Tried hard reset and nothing.
2. Will not Sync...
3. Cracked Digitizer can still operate using buttons and can see LCD Is it possible to chang only Touch part of screen.
Thanks Mike
I can't see Run button in start menu.
Posted on Aug 15, 2008
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
Apr 03, 2012 | Tablets & eReaders
Rca L40FHD41is stuck on menu,cant change input or volume . how to reset the tv???
Unplug the TV for a few minutes it should reset itself.
Make sure the menu button is not stuck, if it is try cleaning the button.
www.aaatvservice.com
Jan 28, 2012 | RCA Televison & Video
I need to master reset may Motorola Blur
To Hard Reset the Motorola BLUR MB300 quite differs from other Motorola ANDROID phones.
Do back up all your data stored on your device before doing this procedure, this process will delete all the data on the phone but does not delete the data stored on the microSD memory card.
To hard reset Motorola BLUR MB300
1. Power off phone.
2. Hold camera button and power on phone at the same time.
3. Release the camera button when prompted to.
4. You will see a message screen telling you to press the up or down volume button
5. Press and HOLD the down volume key (ignore message 'Volume Up Key Pressed')
6. When triangle and phone screen appears
7. Press on the screen just above the back key
8. You will now see the "Motorola system recovery" menu
At this point you will have three choices:
1. reboot system now [Menu+Back]
2. apply ssdcrad:update.zip [Alt+S]
3. wipedata/factory reset [Alt+W]
You can simply tap an item to select it.
At the bottom of the screen you can select OK to apply your choice from the menu.
There is also an opportunity to select Hide on the bottom left, I don't know what that does (I tried it and nothing happened).
Selecting Wipe data/factory reset and tapping Ok and the screen changes to a box and a phone (Get it - out of the box) and you see what is happening on the phone.
pick 2
-- Wiping data...
Formatting DATA:...
Formatting CACHE:...
Data Wipe Complete.
Press Menu+Back to reboot
pressing Menu+Back did nothing for me so I tapped 'reboot system now' on the menu and Ok.
The phone restart then will restore back to its factory default state.
Mar 20, 2011 | Motorola Cell Phones
Smashed my screen on my mda vario got a new phone now want to active sync in but cant remember my pssword is there a work around?
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
Feb 05, 2011 | T-Mobile MDA Vario Smartphone
Htc touch is stuck on ailgn screen
Do a Soft or Hard Reset .
HTC Touch Hard Reset
Power on.
Press and hold buttons marked 1.
Press and release 2 with stylus.
Release buttons marked 1 when menu comes up.
Press directly down on center dpad, marked 3.
Feb 03, 2011 | HTC Touch HD Smartphone
My iPhone is stuck on the white screen but i cant really use it..i tried to restore it on itunes but i cant since it has a passcode but i cant type it in because the screens white and i cant see the...
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Jan 27, 2011 | Apple iPhone Smartphone
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Feb 02, 2009 | HTC Touch HD Smartphone
Stuck on MITS screen, will not start windows mobile
try a hard reset i tell u how:
1.press and hold the reset button
2. dont let go yet! push the power slider down at the same time
3. let go of the reset button, wait a few seconds then let go of power slider and it should work
else u may need 2 get a new phone or try a firmware upgrade
Jan 17, 2009 | Samsung SCH-i730 Pocket PC
Ipod nano 8gb
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Oct 21, 2008 | Apple iPod nano
RIM BlackBerry  Pearl  8100 Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
