Question about Dremel Garden
How do you change the bit on the Dremel Moto-Tool Model 395 type 4
5 Suggested Answers
laseramp
  • 311 Answers
SOURCE: No operation
Hello their, thanks for trying fixya, the issue with these type of tools is normally the ac motor, their are many diffident types used but yours in particular 120V, 50-60 Hz, AC, 1.15 amp double insulated motor. Operates from 5,000 to 30,000 RP, their is a electric motor that may have failed on you or the switch could burned out. this is possible when the contacts are shorted for to long become to hot and overload the small circuit used to control potential voltages to the motor, consider it like a variable pot switch.
a simple test here would be you can take the unit apart easily enough and unplug from wall, make sure you have no voltage from mains going in. when the unit is not plugged in get your trusty voltage ohm meter or vom
Posted on Nov 27, 2009
apenning
SOURCE: My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
Inside the tool is a flex coupling and spline driver.
The flex coupling is # 2615294309 and the price is $ 1.25.
This is the hollow plastic sleeve about 1" long with grooves on the
inside, that goes between the motor shaft and the output shaft.
The spline driver is # 2615294308 at $ 1.00.
Spline driver sits on the direct end of the motor shaft. The flex
coupling sits over the spline driver. Spline driver is about 1/4",
hard plastic with grooves on the outside.
Total shipping for orders under $ 5.00 is $ 2.50. Orders over $
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
Posted on Apr 17, 2010
  • 700 Answers
SOURCE: I do not know how
it is easy, you may find first time that it will not be so, but if you follow advice, it will become even more easy.
1. switch off motor
2. unplug from power
3. find button on the base close to rotating bit, press and hold, this is shaft lock which if applied correctly (you may need to rotate shaft a bit till it fully engage) will stop shaft from rotating
4. apply small spanner (provided with set) to collet collar (collet have two indentations fitting perfectly little spanner)
5. if shaft is held up, turn spanner anticlockwise, then use your hand to undo collar completely
6. remove collet and bit - separate bit from collet
7. collet comes in many sizes, select correct size for new bit
8. insert collet into throat
9. lightly screw in collar
10, insert new bit, at least 2/3 of the bit shank must be inserted into the collet!
11. held shaft lock button pressed
12 hand tighten the collar till bit is locked firmly in place
13. do not use spanner to tighten! if collar do not held properly, re-tighten by hand only!
14. wear always glasses when operating dremmel, or any other rotating machinery, it is not a toy! and exploding bit will penetrate not only your bit of woo, or metal but your eye as well... and your have only two and no spares...
if you find my advice useful, please do not hesitate to vote4 for me, or leave comment, or both... thanx!
Posted on Aug 04, 2010
  • 3 Answers
SOURCE: dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Posted on Sep 26, 2010
Dremel will not turn on?
IF you don't release the bit lock, it won't run.
Aug 01, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Dremel moto tool model 395 coupling from motor to
Jul 19, 2010 | Dremel 395 Variable Speed Multipro Rotary...
My Dremel 395 type 4 does not run until I spin the chuck and then only runs at high speed.
Sounds like a switch or brushes. You can go to Dremel.com and they have a toll free number for their tech services and you can also download a breakdown for this tool.
Jul 13, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel Model 395 Type 3 Plastic Drive Shaft Connection broke into pieces. Replacement needed.
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
Apr 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Dremel Moto-tool model 395 type 1 lock
You can either go to Dremel.com and type in your model number for replacement parts or call their toll free number at 1-800-437-3635 and get that information. Let me know if you need anything further
Feb 20, 2009 | Dremel Variable - Speed Multipro Rotary...
Broken flex shaft on Dremel model 232 broke
You can go to Dremel.com and find assistance or call their toll free number at 1-800-437-3635 and speak with their tech assistance. Let me know if you still need more help. Also I tried using the model number provided and it came up empty that is why I am directing you to this site yourself.
Feb 15, 2009 | Dremel Variable - Speed Multipro Rotary...
Garden Logo
44 people viewed this question
Top Dremel Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Dremel Garden Expert? Answer questions, earn points and help others
