Question about Technics SA-DX750 Receiver
Hola tengo un equipo technics modelo sa-dx750 y me esta dando un error que es el F70 quiero saber porque y de donde se origina ese problema en el cual me anula todo y aca en argentina quien me lo puede solucionar gracias
Grubhead
  • 5126 Answers
SOURCE: on switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Posted on Mar 09, 2010
SOURCE: amplificador panasonic modelo sa-he7, se pone en error f70
rafatecnico amigo mio el error esta en la placa de coneccion de dispositivos auxiliares por favor revisa soldaduras de los dos transistores de potencia que se encuentran juntos y de los dos transistores de acople de los de potencia, si se encuentran bien entonces alguno de ellos esta averiado en cortocircuito o abierto
Posted on Aug 04, 2010
SOURCE: SA-DX750 error F70
I have a technics sa dx 750 receiver that cut...
Posted on Jan 03, 2011
ripleymojica
  • 643 Answers
SOURCE: Problem with the Technics SA-DX750
bad powersupply.
Posted on Mar 21, 2011
  • 184 Answers
SOURCE: I have a Technics SA
Hi!
The F70 error certainly indicates a blown fuse inside.
The real problem is why the fuse is blown: there are only two possible reasons
1. there is a short circuit on the output (lines or speakers)
2. you have a blown output transistor (and that means some work and skills to replace).
To be sure, please change the fuse with a same rated fuse (buy more than one because it can blow again). Disconnect the speakers and turn the amp on. If the fuse blows again, it is sure something wrong with the output transistors. If the fuse remains ok, then please check all the wiring to the speakers.
Hope it helped.
Regards,
Bogdan
Posted on Aug 21, 2011
Donde se encuentra el sensor map baro de mi nissan sentra 2000 1.8
Hola, eso se encuntre entre la manguera en donde entra aire a la cabina en donde se encuentra el filtro de Aire. Incluire un video para que veas en donde esta. Buena Suerte!
Jan 13, 2014 | 2000 Nissan Sentra
Mi malibu maxx 2004 necesita un cambio de aceite cuando lo compre me dijeron qe el aceite que lleva es color azul pero me dicen que no existe ese color!
hola , tengo un carro malibu 2004 , y creo ke esta kemando aceite , hoy ke trate de prenderlo me encendio la luz del motor , le cheke el aceite y le asia falta , le puse , pero la luz no se le apaga y cuando le aselero tiembla cual podria ser el problema , me podrian guiar por favor
May 29, 2012 | 2004 Chevrolet Malibu Maxx
HOLA SOY SANDRA, TENGO PROBLEMAS CON MI REFRIGERADOR WHIRPOOL WRT 18AEC EL CONGELADOR NO SE APAGA ESTA PRENDIDO DESDE AYER, Y NO ENCUENTRO EL MANUAL. ME PUEDEN AYUDAR . MUCHAS GRACIAS
Hi!! Primero asegurate que el control de la temperatura del congelador este aproximadamente en el numero 3. Cuando dices que el congelador no se apaga, quieres decir que el ventilador del congelador esta prendido siempre, correcto? Si el ventilador esta prendido, el compressor y el ventilador que estan abajo, detras del refri tambien deben de estar prendidos chequea por favor. Si esto es correcto, desconnecta el refrigerador por unos 20 min. y luego lo connectas de nuevo, esto hara que el timer se haga reset, si ese es el caso, el problema se solucionara. Si no me envias un comentario y tratamos algo mas. Estuve buscando un manual para tu unidad pero no he encontrado ninguno en espanol, voy a seguir buscando.
Si le haces click en este link, te va a llevar a donde esta un diagrama de las partes the tu unidad, si tenemos que tratar algo mas, te va a ser util para saber cuales son las partes y sus nombres y me puedas entender mejor. http://shared.whirlpoolcorp.com/assets/pdfs/literature/Parts%20List%20(SP)%20-%20WRT18AECLM00.pdf
Avisame lo que pase por favor.
Jan 11, 2011 | Refrigerators
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Hola, tengo una computadora acer aspire one, al encenderla me sale un letrero diciendo que se ha producido un error en el disco que pulse ctrl+alt+del para reiniciar el equipo, pero al hacerlo sigue...
Puedo ayudar, pero, no puedo hablar el espanol mejor. Si tu tienes un dispositivo de U. S. B. en la computatore, puede causar esta problema. Si usted elimina el dispositivo antes de la puesta en marcha, puede ayudar.
Ingles es mi idioma primera, lo siento.
Jul 13, 2010 | Acer Aspire One PC Notebook
Tengo una camioneta isuzu y se acelera y
Hola Ruben
No estoy seguro, pero tengo un Amigo 90 que le pasa lo mismo.  Según creo el problema está en los controles electrónicos de las válvulas (esos aditamentos que están a la izquierda del carburador, segun lo ves desde el frente, sobre la salpicadera derecha del auto)
No se como se corrige el problema.  Supongo que cambiando los controles de las válvulas.  Una cosa que puedes revisar es que las mangueras que comunican el carburador con esas piezas que te menciono no tengan entradas de aire por grietas por resequedad.
Si alguien más sabe una solución mejor, espero con gusto su respuesta.
Yo quisiera cambiar el carburador por uno 100% mecánico mejor
Oct 03, 2009 | 1993 Isuzu Amigo
Error en sistema 0013 en BenQ DC610
CBCX, efectivamente el error se debe a que el lente se trabo y no pasa las pruebas movimiento iniciales que hace el equipo al encender. Por esta razón aparece el error de 0013. Mi experiencia a sido que el engrane que provee de este movimiento se sale de su posición original provocando que se trabe. Yo tengo una cámara del mismo modelo. El problema se resuelve abriendo la cámara y ajustando el engranaje (Es un pequeño engranaje rojo que esta en la parte superior del lente). Adicionalmente se debe fijar el soporte del engranaje, yo coloque un poco de cinta adhesiva en el soporte del engranaje para que no se mueva nuevamente. Esto en la mayoría de los casos resuelve el problema de manera permanente. Adicionalmente es recomendable actualizar la última versión de firmware del equipo.
Como referencia, he descubierto que si estas en el campo tomando fotografías y te ocurre el problema, si le das un golpe firme con el pulgar, en la parte delantera de la cámara justo entre el flash y el emisor para el ajuste del foco el problema también se solventa de forma temporal ya que el engrane entra nuevamente en posición. Puedes hacerlo también dentro del estuche de la cámara con la palma de la mano. A pesar que esto nunca falla, el equipo queda funcionando nuevamente, esta reparación es de carácter temporal y adicionalmente, es obvio que no es sano recomiendan esta práctica, pero puede salvarte en caso de que estés de viaje tomando fotografías y no tengas un servicio especializado.
Feb 03, 2009 | Nikon Coolpix 3200 Digital Camera
Porque mi placa se recalienta tanto donde se encuentra el procesador y la tarjeta de video
Hola te recomiendo un sistema de este tipo, ami me pasaba y con esto se soluciono ese problema http://www.bit-tech.net/hardware/cooling/2012/09/26/thermaltake-water-2-0-performer-pro-reviews/1 9ab6aa7c-9dc3-4642-ab5a-d10391656423.jpg
Oct 01, 2008 | Intel D865GBF Motherboard
GR-DX75US
Hola Lucio
Yo sot de Argentina y me pasó lo mismo que a vos, llamé a representante en Argentina y me dicen que ellos no lo pueden arreglar porque la camara fue comprada afuera de Argentina, esto es una locura ya que en todo el mundo las están arreglando gratis. Decime como hiciste si es que lograste solucionar el problema
Saludos
Nov 15, 2007 | JVC Cybercam GR-DX75 Mini DV Digital...
Technics SA-DX750 Receiver Logo
118 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
