Question about Dell 968 All-In-One Printer
My printer is having problems printing color pictures. They are coming out blurred. The printer is very noisy as well. It says there is an obstruction in the printer but there isn't anything blocking anything.
  • 857 Answers
Follow all these steps to fix your problem :
1.
Turn the printer on and open the top cover.
2.
If the printer makes a loud grinding noise and the carriage assembly is stuck behind the right side of the printer, one of the ink cartridges may not be completely locked into the carriage assembly.
*Turn the printer off and locate the capping station on the right side of the printer below the carriage assembly.
-Turn the printer on and as the capping station lowers or a grinding noise occurs, unplug the power cord from the back of the printer.
-Pull the carriage assembly to the center of the printer. (One or both of the ink cartridges may need to be pushed toward the back of the printer so they do not keep the carriage assembly from moving to the center of the printer.)
-Remove the ink cartridges and verify that there are no parts damaged or broken.
-Reinstall the ink cartridges in the carriage assembly making sure the ink cartridges are firmly locked into place.
-Plug in the power cord and turn the printer on.
3.
Print a self-test with the top cover of the printer open and the output paper tray removed to try to determine where the noise is coming from.
-When the printer is turned on and the top cover is open, remove the output paper tray.
-Push the RESUME button once and the carriage assembly should return to the right side of the printer.
-Hold the RESUME button down until the printer begins to print a self-test.
4.
If the carriage assembly stalls on the left side of the printer, verify that the clutch actuator arm (slider arm) is correctly positioned.
-Unplug the power cord from the back of the printer.
-Slide the carriage assembly away from the left side of the printer.
-Locate the black or white clutch actuator arm above the metal gear assembly on the left side of the printer. Verify that the downward pointing "tooth" or "arrow" on the right edge of the clutch actuator arm is positioned to the right of the metal gear and plastic half-gear assembly below the clutch actuator arm.
-If the arrow on the clutch actuator is stuck between the metal gear and plastic half-gear (see Figure 1), lift the clutch actuator and move the arrow to the right of the plastic half-gear (see Figure 2). Once the arrow on the clutch actuator is to the right of the gears, the clutch actuator should move freely right and left 12.7 mm (0.5 inches).
-Replace the upper (OUT) paper tray, close the lid, plug in the power cord, and repeat Step 3 above to verify that the noise is gone.
5.
If the printer is making a clanking or chattering sound as it prints, the printer may require repair, contact the Customer Care Center.
6.
If the paper jams in the printer or becomes scratched as it is feeding through the printer, verify that the pinch springs or rollers are not damaged or missing. Also verify that nothing is stuck under the paper sensors by following the steps below.
-Turn the printer off and unplug the power cord in the back of the printer.
-Verify that the three small brown rollers are pressing against the three larger black paper feed rollers. Also, verify that the three metal pinch springs are pressing against the larger black paper feed rollers (except for the center pinch spring, which should be pressing against the metal guide surface).
-If one of the brown rollers or pinch springs is damaged or missing, the printer should be sent in for repair.
-Verify that nothing is stuck under the two black rectangular paper sensors located between the three pinch springs. Lift up on the sensors and blow air under them to dislodge any particles that may be stuck under them.
-Plug in the power cord and repeat Step 3 above to verify that the noise is gone.
7.
Sometimes intermittent noises from the printer can be caused by the drive belt slipping over the gears. Clean and lubricat the bar with some silicon lubricant such as WD40 by spraying it on a paper towel and running it across the bar two or three times.
Posted on Oct 03, 2010
Colors print blurred
you need to run the nozzle deep cleaning utility, nozzle check and alignment procedure under the printer properties maintenance tab.
Please rate this solution. Thanks.
May 27, 2010 | Canon i860 InkJet Photo Printer
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Blurred printing new black cartridge installed - we still have blurred printing.
It is problem on cartridge setting may be it select color cartridge.or clean your black cartridge check nozzle print test.
Feb 12, 2010 | Canon PIXMA iP5300 InkJet Photo Printer
Describe your Ricoh Aficio 1232C Error Code SC481 Problem
Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
Right from the service manual
My best guess is belt mark blurred or missing
or image belt out of position
Feb 01, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
Blurred printing
run the printer configuration in the Properties of the printer. It's in the Control panel. Next time please add printer model number, motherboard model number, and Operating System version to be more descriptive in our solutions to your problem.
Jan 02, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon MP145 Blur Printing
maybe u should check the printing setting/preferences, maybe it is set to general or normal... im not that familiar with the canon scanner.. i have an hp printer which is a scanner too, when i print pictures direct or from pc, i always check the settings before printing like setting to best resolution, setting to photo printing etc...
Sep 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hp color laserjet 1600 copies have a blurred image
This sounds like a registration problem.
Use the menu (on the printer) to print antest page AND a configuration/information page.
Look (critically) at the alignment of the seperate coloure Yellow Magenta Cyan. You will probably find that these are out of aligmnent across the page.
The cause of this, is that the printer can't perform a calibration properly (printer probably takes a long time when calibrating too) and is usually down to failure of one of the sensors on the transfer belt.
Sometimes you can clean these and solve the problem, but often is a failure of the component itself. Thes are NOT available as a spare part, and the repair to correct this would need a replacement transfer belt.
Transfer belt replacement in this printer is quite an involved task, though it is within the capabilities of someone with reasonable mechanical aptitude.
Nov 24, 2008 | HP LaserJet 1600 Printer
Blurred printing printer i255
Hi, check the nozzle and test , if the result not in solid color there are spaces within the color means need head cleaning after head cleaning twice test print .
Jan 23, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Printer not printing full picture.
Check your settings and make sure you are setup for the right photo paper if you are, then try updating your driver.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Nov 01, 2007 | Kodak EasyShare Color Photo Printer Dock
Dell 968 All-In-One Printer Logo
115 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
