Question about Refrigerators
How to remove the Liebherr ice maker on a bottom freezer - I see no screws anywhere
  • 72 Answers
SOURCE: Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Posted on Jun 17, 2009
SOURCE: Kenmore Bottom Freezer 596.71103101 Ice maker not working right
When the refrigerator was moved, the freezer door may have shifted downward. The switch for the freezer light is on the top of the freezer so it turns off the light when the door closes. The icemaker is also connected to that switch so it won't dump ice when the door is open. The solution is to adjust the door elevation. The easier solution is to attach something to the portion of the door that hits the switch. I used a white coverplate for a wall light switch.
Posted on Jan 15, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Posted on Apr 28, 2009
SOURCE: ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Posted on Jul 25, 2009
SOURCE: blue ice from ice maker
Ive had this same problem!! Blue ice... They denied it. Then suddenly sent someone out to change one washer....! But its still there, maybe its because there is another one!
Watch out big time for these guys! Thanks for info
Posted on Jan 12, 2010
Liebherr ice maker not making ice. Switched on but nothing happening
Hello Irene Booth,
There are several things you can do to check the suitability of your freezer settings ... (eg: if you put a small container of water in the freezer...
Is it mostly frozen in about 45 minutes??
Things that would aid in trouble shooting...
Liebherr nomenclature: model number...???
New... or new to you?
Had previously worked... Never worked.
General observations... Frost forming in back of freezer area
Doors square and fitting properly...
Gasket in full contact (visibly) all the way around the freezer door/drawer... and is in good condition
- (can physically check by pulling a dollar around the gasket).
If the Ice Maker has EVER worked ... We can skip the basics of checking the water supply is hooked up and TURNED ON.
If you can fit your fingers in the ice tray to feel for water or ice in
the tray ... that would also be helpful.
Finally... for new models... check that all packing tape & materials around the ice-maker have been remove.
Although your model appears to be a TWIST TRAY type of ice-maker... there is still a sweep or fill bar that is supposed to check the fill level of your ice bin.
A single chip of ice can hold that from moving freely... your ice maker will not work ... !!
Hope this helps
Carnac the Magnificent
Jan 04, 2017 | Liebherr Refrigerators
Where is the water filter for Liebherr CI1650 located?
There isn't a water filter. You should install an inline filter to the water line that comes in to feed the ice maker.
Jun 18, 2014 | Liebherr CI1650 30" Built-in...
I have a Liebherr free standing french door frig (two freezer drawers). The plastic component that shapes the ice cubes has fallen out of the ice maker into the ice receptacle below. I don't know how to...
I don't know about this ice maker, but you could always check the Owner's Manual (either the one that came with fridge, or an online copy) for re-attachment info. That's something basic that the manual may very well cover.
Sep 18, 2013 | Liebherr CS2062 Bottom Freezer French Door...
The ice maker appears not to be working can not
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
May 31, 2010 | Liebherr KIKNV3056 Bottom Freezer...
The fridge and the bottom freezer are working fine. However there is a lot of ice developing at the bottom of the (bottom) freezer. Although we recently de-frosted the freezer and removed the ice (water),...
there is only 2 things if you dont have an ice maker inside your door is not sealing all the way around or the drain is cloged with ice and everytime the ref goes into defrost the water leak into the fzr unplug for 2 days that shoud fix it
May 30, 2010 | Liebherr KGBN 3846 Premium BioFresh Bottom...
I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Freezers
Ice maker has stopped
hello. i have the same problem. did you find a solution? thanks so much!
May 25, 2009 | Liebherr KIKNV3056 Bottom Freezer...
Refrigerators Logo
732 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
