Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Stand by light keep flashing and I cant reset it
Change all electrolytic caps in the power supply first
Posted on Oct 04, 2010
Replaced lamp now lamp light keeps flashing still also the stand by temp light flashes
Sounds like a door switch is not making proper contact--or has been damaged. Check the lamp door switch and see if it is properly seated and the pin on the door is hitting the leaf of the switch.
Mar 06, 2014 | Samsung HL Televison & Video
Dishwasher will not work
I had the same problem. on the same machine. when this light flashes it means that it cant easily intake or drain the water. just clear the filter located down the tube and clean all of its parts and the valve wich is down from a metal stipe next to the filter. after this press continiously the start button. this should do it!!!!
Dec 11, 2012 | Miele 24 in. G692SC Plus SS Free-standing...
The light on my magnavox converter keeps flashing green then goes to stand by mode
mine is doing this too, i called Magnavox support and they aid it is an internal power issue and cant be fixed by troubleshooting, it has to be serviced. imo, probably cheaper to buy another.
Nov 06, 2012 | Magnavox (TB100MG9) Video Converter
How to reset check engine light?
Go to your local O'Rielly's or Autozone. They will tell you the code and reset it for free. Otherwise take the negative battery cable loose for about 10 min. This will clear the ECM, but you won't know what tripped the light! Best Wishes, TJ
Aug 06, 2011 | 2007 Hyundai Azera Limited Sedan
The clean light keeps flashing, and we cant cancel the program or get it to wash
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Dec 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
32 in. Sony Trinitron stand by light keeps flashing
has a sony 41" REAR PROJECTION TV THE STAND BY LAMP IS BLINLING HAS RESET IT , NOTHING. HAS NO PICTURE NO SOUND
Jul 31, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Stand by light just keeps on flashing red and i cant press any otehr buttons it just keeps flashing red
something inside the unit has caused it to go on protect mode it sounds. check the v supply from the fan as well as the audio output ic and main pc board.
Jul 05, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Mitsubishi 3.5 split systme fault
green light flashing means there was a fault that occurred now it could be power failure which you can try to reset by turning off and on circuit breaker it might reset itself if not there is much bigger problem which need technician
May 10, 2009 | Heating & Cooling
How do i reset my dishwasher adp4504 . i have kept my finger on the start button but just keeps on flashing
Hi!
Try pressing sani rinse and heated dry back and forth. All the lights will light and it will reset itself.
Please see this link for more information---
Whirlpool dishwasher reset
Please rate the solution if found useful.
Thanks
Rylee
Feb 24, 2009 | Whirlpool 18 in. ADP530 Free-standing...
Flashing
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Sep 10, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
