Question about Sharp AQUOS LC-C6554U 65 in. HDTV LCD TV
THE LIGHT GREEN IS BLINKING AND I HAVE NO PICTURE AND SOUND
  • 10 more comments
  • dbest826 Oct 03, 2010
    I did that already, I have a professional take a look at the power supply and there is no sign of burned fuse. he said all fuse 250 volts 50 amps are good, what should I do next
    we have done that too, thanks, but you arent helping much.
    I will like for another expert, thank you
    Yeah, I have a professional tech here, who checked everything and nothing seem to be burned, is there any terms or any part, he should be looking at, that he is missing at the time? Like any especific fuse or part or anything?
    just to make it a little simpler for him to fix
    I will need the power supply modules, or a way to reset the TV...
    he said it could be the power supply, but because it has happen that after you buy the power supply the problems stay the same. so before i go spending money, i want to make sure, i have been thru everything that can be checked at the tv... He just took both boards (power supply) and will be running test from home. but i want to make sure that i dont spend money if is fixible.
    i bought this tv in july 2008, from bj's wholesale. you think it still has warranty?
    yeah as silly as it sounds, thats what i am doing, asking you to help me, as the professional tech is here, he is a "neighbor" and i just want to confirm that we are both on the same page, and that he is looking at the problem the right way. It has been 1 week since this problem happen, and we still cant find nothing with it... he is a bit confuse with this "model" and will like to know hints on what to look further into that he might off missed.
    no i bought the tv with a bank card, dont have any credit card, ok i will have him check the power board, anything that you might look in to it that might help?
    anyway, thanks for your help... I just hope is the power supply, but he claims no fuse are burned, but he still believe we should replace it.. he took both parts home to try to find the problem, so lets see what happens. thanks!
    how much you think this might run me for?
  • 10,594 Answers
Unplug tv from wall socket for minute to get reset power supply then replug back in and turn it On
If still green light flashing and no picture or sound then it looks some serious issue in circuit boards and tv needs visual check by professional.
If tv is under warranty then call on number written on tv warranty documents to ask them warranty cover.
Thanks.
Posted on Oct 03, 2010
  • Shahid Electronics
    Shahid Electronics Oct 03, 2010
    Is is Sharp LC-C6554U tv or any other model?
    You should have service manual copy to troubleshoot as per instructions mentioned in that service manual.
    Yes, I feel that, reject my assistance please
    Thank you
  • Sharp Master
  • 11,800 Answers
The green blinking light signals the fact that the power source is in protected mode - the source has been shut down because there's a big short on one of it's output power lines. This is usually caused by either the failure of the power source itself or because the inverter board has failed. You said that the repair man has taken them both for further testing - this is exactly what i would have done.
The power board is probably fixable, but the inverter board if it's dead it will have to be replaced - when it fails it fails the big way, completely frying itself and sometimes the power source.
Yes, the tv is fixable - worst case it will cost you $250 for the boards plus labor to replace them.
No, the tv is no longer in warranty, it expired a few weeks ago, after 2 years.
    President:
  • 2,777 Answers
Sounds like a failed or at least failing power supply / power board inside the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will need to contact a local TV repair person in your area. If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
So sorry that I don't have better news but it is definitely a power issue internally.
Thanks
Tim
  • 4 more comments
  • Tim Grayson
    Tim Grayson Oct 03, 2010
    Ok well you won't necessarily be seeing anything burned... It can be the main board as well. I would check into the option of filing a claim on this TV if you can, but it sounds like you can't. It can be the main board, or video board as well. Who is this person that said the voltages were fine? The "he" you referred to? Can they help you fix it? It is sometimes impossible to tell that a board is damaged until you swap it with a new board.
    Tim
  • Tim Grayson
    Oh wow, I see, a professional..... So they were able to tell you that it wasn't the power supply, so what did they say it was?
    Tim
  • Tim Grayson
    You want the power supply modules? What do you mean? You want to know the part # of the power supply? I'm sorry, I'm confused here... you have a "professional" in person but are still consulting us as well?
    Tim
  • Tim Grayson
    If you read my comment, no it will not have a warranty from "BJ's" but if you bought it with a card like American Express it has a warranty through them. I have successfully warrantied 2, and 4 year old TV's through AmEx and received full refunds multiple times.
    I still believe it is that power board.
    Tim
  • Tim Grayson
    Ok that makes more sense. I am still quite certain the power supply is the issue. If he finds it is not, then it would either be the main board of the TV, or the video board on this particular model, although either of those would be very rare.
    Thanks
    Tim
  • Tim Grayson
    Sounds good, and as mentioned it may appear fine but many times it is still bad, I would bet for sure it's the power supply.
    Tim
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered. The board with the power...
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict..
iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
Oct 20, 2015 | Sharp LC-42D72U 42 Flat Panel 1080p...
Slim and secure blinking green light
Same problem here... Blinking green light. Purchased new battery and is still doing the same thing. Very disappointed-these cameras are not cheap. :(
Mar 10, 2012 | Summer Infant Slim Secure Handheld Video...
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Dan
Jun 19, 2008 | Televison & Video
Blinking green light, no picture or sound
Hi, bought television only 2 months ago now blinking opc light and power lights with no picture or sound. Whats up with that?
Sep 13, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Sharp AQUOS LC-C6554U 65 in. HDTV LCD TV Logo
272 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
