Question about Sony PlayStation 2 (PS2) Console
PS2 SCPH-5001 DRE Dual white len adjust wheels. cleaned lens tried adjusting dual white wheels still DRE on all games.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 273 Answers
Http://ebookpedia.net/The-Powerful-Playstation-2-Repair-Guide.html
Posted on Oct 12, 2010
Ps2 freezing games
I was experiencing the same problem on my ps2 slim scph-90004. When I put a game in my ps2 it loads but after some time it just freezes at the same spot.I went to many shops but they dont recognize my problem.Then i open my ps2 slim (Warning:Opening of ps2 my void your warranty) and saw the lens which was not adjusted. SO,if you are experiencing the same problem then use the above method(For slim only).Look at the rod near the lens which has two small clips on it. Open the screws on the clips and take out your ps2 lens.Clean it with a cotton.Set the lens in some different position and load your games .
Apr 20, 2013 | Sony PlayStation 2 (PS2) Console
My ps2 slim wont read god of war II disc but it reads all my other games just fine so please i need a solution
God of War II being one of the few Dual-Layer discs on the PS2, it is possible that your problem originates from your PS2 lens being unable to read it correctly. The PS2 Slim is supposed to be able to read Dual-Layer, thus you should try cleaning your lens, it may be dirty, leading to this kind of error while still able to read Single-Layer discs.
-Organicbeing
May 14, 2011 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error is mainly due to worn-out,dirty lens and it can also appear because of the disc that you have inserted in your PS2......
Try following to get rid of DISC READ ERROR:
  • Clean your PS2 lens:
Watch this video first
This will help you in cleaning the lens.You can also clean your PS2 lens by some lens cleaning DISC.Make sure not to touch lens with your hand.
  • Clean your DISC:
Watch this one to clean your DISC
Thank you!!!
Nov 12, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 slim clicking problem
Your lens is repeatedly touching the disc. In the future, this could be a big issue, and it is a sign that your lens is breaking down. On the slimline models, specifically SCPH-70000 models or greater, the lasers are disposable just about. They weaken easily, and they stop working fast. You can get a new laser for about 20 dollars from some websites.
Check some of your discs. If you notice any circular scratches, you'll know that your lens is touching the disc. Does it still read PSX, PS2 games (including DVD-9 dual layer games like Guitar Hero) well? Does it read fast? Can you still watch movies on your PS2? If not, your lens is breaking and you'll need to replace it.
Sep 12, 2009 | Sony PlayStation 2 (PS2) Compact System...
My PS2 will play DVD, But I get disk read error when I try to play a game. I have already took it apart and cleaned the lens, and also adjusted the lens wheel.
well it´s time to change the laser lens...you can force adjusting the dvd laser focus in the micro pot located under the ps2 lens...but it´s better to buy a new lens unit..
http://www.diytrade.com/china/4/products/5366609/PS2_PVR-802W_LASER_LENS.html
Sep 10, 2009 | Sony PlayStation 2 (PS2) Console
Sony PS2 SCPH-30003 No data error. PLS Help
You should never open any DRIVES like DVD or CD drives even for your PS2, There has to be a problem with you lens in your PS2.
Mar 07, 2008 | Sony PlayStation 2 (PS2) Console
Adjusting the lens height using the gear
first do what i did. get a dvd movie,a ps one game,a cd based ps2 game (timesplitters,rune,dynasty warriors 2,half life)a dvd based ps2 game, and a scratched ps2 game. first adjust the azimuth(the torx screw to the left of the laser} make sure you use a cue tip and 91% alcohol on the lens and under the lens(you have to remove the black cover off the laser). I just got a broken ps2 for 5 bucks and that made it work perfectly.make the azimuth adjustments in 1/8 turns. try all games and especially the dvd movie carefully pull the white plastic wheel out of the top cover for the dvd drive. and pop that on the disk while its in the drive. turn it on and note what happens. if a disk is in the drive before it's powered on you should never see the browser it should just boot.If not you have problems. once all disks are booting good get a problem disk (I used a scratched tony hawk 3) and if the audio skips or freezes adjust the white cog wheel counterclockwise in 5 click intervals until it works perfect. if you are lucky it will work like new if not you might have a laser voltage problem and to fix that you need a variable scope ososcillator ( i know i missplelled it) under the laser is 2 pots to adjust the voltage for the cd laser and the dvd laser. the left is the cd one if its facing you. you can find the proper waveform pattern online in various places.i would just buy a Used ps2 because there preety chaep and definetly cheaper than the stuff needed to adjust the voltage correctly.IF YOU TRY TO ADJUST THE LASER YOU MAY BURN IT OUT.I did on my first one but since my friend was using it as a window stop and i got it for free i donn't care.So hopefully it works out for you guys. if i were you just buy a SEGA DREAMCAST it has none of these problems and is cheap as hell..............................................
Jun 27, 2007 | Sony PlayStation 2 (PS2) Console
Problem reading dvd movies
You need to have your lens cleaned and or adjusted. i suggest you not try it because you can actually break it and or make it worse. My company will be more than happy to fix this problem. Thank you, connie
Jun 11, 2007 | Sony PlayStation 2 Slimline Console
Disk not spinning but laser is lit
i had this same problem countless times, the problem is the laser what you have to do is open it up get a bud and some ethanol(becareful some ethanols are made oily to prevent child consumption avid these one) then gently wipe the lens and clean out the rest of the console with a hairdryer and VOILA
Apr 18, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
304 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
