I just bought an old 70s zenith integrated stereo system with allegro 1000 speakers. it has a radio, 8-track, cassette and record player. everything works, but i can't get the record player switch to move from the off position... it seems mechanically stuck somehow... i've tried rotating the console to reset the mechanics, but still no use. any suggestions?
SOURCE: Tascam Porta-One 4-track cassette studio
I had this problem; much of the trouble seemed to come down to lubricant on all of the plastic gears of the transport assembly that had hardened. I had to send it to a fellow in New Jersey who specializes in the Porta One and he basically had to take apart the transport, clean the plastic parts, and put it back together again.
If you're very very handy, you can find the service manual online. It will not show you how to do any of this, but it will include exploded diagrams of the machine and tell you the name of the parts so that when you lose some random dingus or frammus under the couch, you'll know what to look for online to replace it.
Posted on Dec 18, 2007
Buffalo12980
  • 625 Answers
SOURCE: RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Posted on Dec 31, 2007
  • 11 Answers
SOURCE: cassette drive turns, speakers hiss but no music
Mode switch trouble! no audio from cassette function?
Posted on Feb 26, 2009
Grubhead
  • 5190 Answers
SOURCE: Philco Console On/Off Switch
It sounds like the knob part has has lost grip on the spindle of the switch, due to age. The knob part is designed to pull off (though sometimes they have an allen screw to keep them on) for service. You could try and pull it off! However it could (due to its age) have decayed and so might break up. If you do try to pull it off, turn it to the off position and when you put it back on put the knob pointer at the off point.
However it is safe to operate at the present.
On the 8 track the fixes and myself would need to know more details. Like: does it play, can you put a tape in etc, before giving a verdict.
Posted on Jun 26, 2009
RonPark
  • 855 Answers
SOURCE: An elderly relative has lost a panasonic rq-sx53
Look in your area for any good cassette player they all can play the c90 tapes. All you have to do is have a cassette player. Large stores that have stereo dept. would be a good place to look where you can also hear them to see the sound quality.
Posted on Sep 08, 2009
Zenith turntable/cassette player/8 track. Serial # 934l4, Can't tell if the model # is IS 40 81-3 or 1 S (Or 15 4081), made in Taiwan. Wondered what age it is and if there are tubes inside?
Cassette tapes began to supplant 8 track in the mid 70's, so this is probably a transitional unit. Kind of like now - there are DVD players out there that still have VHS slots. I'd say late 70's and I'd guess no tubes.
Jul 28, 2017 | Zenith Audio Players & Recorders
Does old Zenith Allegro Console Stereo - 8 track/AM/FM/turntable, have a belt drive phono? I can see metal gears to drive the stuck turntable .
The manufacturers of such items would usually buy in such hardware as record turntables from fairly standard catalogues.
One popular brand of turntable was the BSR but the design of other brands were similar. The metal gears aren't for driving the turntable but to drive the multichange mechanism so when one record has finished playing another will drop from the stack loaded onto the extended centre spindle.
This type of turntable is driven by a synchronous motor with a multidiameter spindle via a moveable idler wheel equipped with a soft rubber tyre. Lack of maintenance causes many problems and as the rubber tyre ages it tends to harden and lose traction on the inside of the steel turntable so when the record reaches the end and the metal gears engage there is insufficient torque and everything stops.
It is for that reason many older examples have had the multichange removed or disabled.
Removing the turntable centre motif should reveal a circlip which when removed will allow the turntable to be removed for maintenance.
Jun 07, 2017 | Zenith Televison & Video
Sound Issues with Stereo System
It is more than likely the audio output transistors have shorted out, test equipment will be needed to find out the extent of damage.
Sep 02, 2012 | Audio Players & Recorders
I was attempting to install a new stereo in my 2000 taurus. it requires to an adapter to put the new stereo in. i got the new adapter and stereo in *kinda* but decided i didnt really know what i was...
check your fuses first. You may have blown one.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
  1. If the fault is not visually evident, proceed to diagnose the integrated control panel (ICP) by entering the ICP Self-Diagnostic Mode.
NOTE: To enter the ICP Self-Diagnostic Mode, the ICP must be ON and in radio tuner mode (AM/FM).
  1. Enter the diagnostic mode by pressing and holding preset buttons 3 and 6 simultaneously. This will suspend all radio functions, and display SP.
  1. Preset Button 1 = Audio internal/external SELF TEST. The display will flash SELF while gathering the diagnostic trouble codes (DTCs), then stop flashing when complete. Press the TUNE UP button to display the DTCs if any exist. Record codes and refer to the following table:
ICP SELF-TEST CODES Code Description 0 No diagnostic trouble codes logged 1 No response from rear chassis unit (RCU) 2 No response from cassette player 3 - 4 No response from compact disc player 5 - 6 - 7 No response from remote climate control 8 - 9 Read Only Memory Verification failed
  1. Preset Button 2 = Displays the feature strap for code identification, refer to the following table.
Code Description 01 Base-Electronic Search Radio (ESR) with Manual Climate Control (MCC) 07 Electronic Search Radio with Cassette (ESC) with MCC 17 ESC with Electronic Automatic Temperature Control (EATC) 97 Not programmed default of ESC with EATC
  1. Preset Button 3 = ICP and RCU identification. This test identifies the software level of the ICP and RCU. The ICP is tested first, followed by the RCU. The display will have two sequences of three codes each. The first sequence is for the ICP, the second sequence is for the RCU. For code identification, refer to the following table:
Item Part Number Description 1 - Product variant code 2 - Tape model 3 - CDR
SOFTWARE IDENTIFICATION CODES Product Type Code Description Product Variant Code Description 21 ICP 07
08
09
10
11
12 EATC with AM/FM, cassette player and CD changer
EATC with AM/FM and cassette player
Manual A/C with AM/FM and cassette player
EATC with AM/FM cassette player and CD changer 31 RCU 01
02
03 Analog
Digital
Midline 71 Remote climate control 01 LH drive 52 Compact disc/disc jockey 01
02
03
04 Sony® 10 disc
Sony® 6 disc
Clarion® 6 disc
FMS 6 disc
Sep 13, 2011 | 2000 Ford Taurus
I have an old zenith is4070. I am trying to figure out how many watts it pushes out to my speakers.
Model # IS 4070
AM/FM Stereo Receiver
With Phonograph and Cassette Play/Record
Serial # W288209
Power Source AC 120 V 60 Hz
78 Watts 0.65 Amps
Unswitched
AC 120V 60 Hz
200 W Max
Jul 09, 2011 | Zenith Audio Players & Recorders
Trying to find a way to get the turntable of a Zenith Allegro Console to work. We have turned to whole unit on and off. AM and FM radio plays. Turntable doesn't turn. At the bottom right of the turn...
Lift the turn table off the case and check the belt if it has one or the idler wheel that mechanically turns the table. Also check the motor to see that it rotates when you simulate a record play moving the needle carrier towards the center, The power must be on to test it. Becareful not to touch the 115 VAC line.
Oct 29, 2010 | Audio Players & Recorders
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
Jul 15, 2009 | Audio Players & Recorders
Only records Lps and CDs, but not other cassettes
there are programs on the net that will copy from tape to cd via the computer if you have a cd writer on the pc hope this helps regards Jim
May 02, 2009 | Audio Players & Recorders
215 people viewed this question
 Grubhead
Grubhead
