Question about Whirlpool Duet GHW9150P Front Load Washer
Full of water & won't drain - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 03, 2010
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
Mar 05, 2012 | Washing Machines
Water won't drain
Hello & Welcome to FixYa
As the water did not drain completely then check the drain hose & drain pump filter located inside the front bottom access panel for any clogs/obstructions, if you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 18, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Hi, I just purchased this used. It was working fine for one day, but now it won't turn on. Can u help? Haier CPN12XH9 12000 BTU Portable Air
If the water collection tank is full, it will not turn ON. Since you said the unit worked fine for one day and now it won't turn ON, more than likely, that's the problem. After draining the tank, the unit should reset itself and turn ON like it should.
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan or bowl that's capable of holding up yo a quart of water. O r roll the unit to a floor drain or outside to drain it. If you choose to drain it into a pan, turn the unit OFF & unplug it, before draining it.
I hope this helped you and thanks for choosing FixYa
Jul 25, 2011 | Haier CPN12XH9 Portable Air Conditioner
I have a portable air conditioner model LP0711WNR. My issue is when I drain the air conditioner, it only drains about one cup of water. Then, when I turn it back on it and use it, after about an hour it...
The easiest way, is to tilt it over slightly when you drain it. But, be very careful doing this, as the unit has caster wheels and you don't want it to get away from you. If you have a helper, so much the better. Remember to always turn the unit OFF & Unplug it, before draining the water from the tank.
I hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | LG LP0711WNR Portable Air Conditioner
Once the dishwasher had finished the bottom was full of dirty water which won't drain away and now it wont work at all
More than likely a failed water pump, or blockage that has created a discharge problem. This could cause the circut breaker to trip. So, it is kinda messy, but if you drain the water by hand baling, clean or check the interior bottom d/w discharge intake & screen, reset the breaker, and restart. If the system still does not drain it's probably pump failure. I don't think people actual replace the pump, they just get a new d/w unit. Unless there is warranty coverage.
May 25, 2011 | Hotpoint Dishwashers
Washing won't spin and i have a washing machine full of water , could you tell me how to check the filter ?
First of all you mustt drain the water that is trapped within the drum. So remove the drain pump/ valve and allow the water to flow out - make sure that you have an arrangement to collect water when the drain Hose is removed.
Now the drain pump/valve must be checked clean if there is dirt clogging. Also test the valve for proper functioning. Also check the inlet valve and filter which is on line with the water inlet which can be traced easily. Check the motor, drive , door switch and finally the control board. If after switching on there is no action , inlet filling or spining when water is full, the program controller must be faulty.
May 19, 2011 | Washing Machines
Water goes in and out, timer working but machine is not agitating
Sounds like your drain hose is too low. The drain must be higher than the tub so it won't run out before it gets full. If it is not to the cut off point before the water is as high as the drain the water will run out the drain and never get to the cut off point. It wont agitate untill the water level switch cuts off the water. Hope this will help.
May 03, 2011 | Washing Machines
My GE washer doesn't drain water.Even after the spin cycle is over, the washer is full of water. Please help.
Either the drain is blocked or your filter is full. Find out where the filter is, usually in front below door or behind panel in front. Clean this out & refit. Plug off the mains first. Check machine filter first & then snake out your drain.
Feb 10, 2010 | GE WSXH208A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
