Question about Emerson LC320EM8 32 in. LCD TV
Stand by light is on.when i try to turn on the tv the power light flashes, the screen cuts on and flashes dig tv then cuts off.
  • 644 Answers
The likely problem is bad capacitors on the power/inverter board, to check for them you will need to remove the back cover, there will be a few screws holding together so make sure you find them all, some can be hidden under stickers or rubber incerts, before opening the set unplug from mains, and leave for about an hour or two in ensure the caps inside have had time to drain the voltage, once you have taken the back off the set you will see pcb boards and a few wires, your looking for cylindrical barrel shaped componants on the the board with silver tops, if any of these show signs of leakage or are slightly domed or pretruding at the top they are faulty and will need to be changed.
You will need some soldering skills to remove the capacitors from the board, and replace with the new ones, you can buy the capacitors from places like maplins or other online electrical componant shops such as RS Componants, ensure you know the value of each faulty capacitor, it is written on the side of them it should be somthing like this 25v 47uf, V stands for the voltage, you dont have to exact with voltage as long as it is equal to or more than the voltage stated on the cap, the uf however stands for micro farad and needs to be exact, if the cap is 47uf then you will need to replace it with a 47uf value cap, if not it will not work and may blow, the same if you get a lower rated voltage cap. Also before removing the old caps from the board make a note of which way around they are placed on the pcb board, they will be markings on the side of the cap to show which leg is the negative side or cathode, it will also be marked on the pcb itself. If you get these the wrong way around then the cap will blow. Hope this helps and post back if you need any further help.
Posted on Oct 03, 2010
My Samsung TV won't turn on
Please describe the problem more accurately. Flashing red usually means 'stand-by' state, flashing blue/green - starting up. When (during that) do you have a sound? Are there any 'high voltage' sounds like soft screeching from the screen? Is it LCD or LED?
Mar 02, 2015 | Samsung Televison & Video
T.V. doesnt turn on and red light keeps flashing at Power Section
Ur power board have dead capacitors,Know how to solders?Take the tv aparts check for capacitors puff up or burst open in the power board.Replaced those capacitors.Or tries Shopjimmy.com,Ebay.com buy a refurbih power board.
Jan 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Cannot get tv out of stand by mode..
upon hitting the power button, the red light showing on the front of the tv should flash a couple of times, the screen should come on and the light goes off..the red "stand by " light stays on and we cannot get the screen to come up..needless to say, cannot get to the menu to change any display options...any suggestions?
Apr 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Stand by mode
How many times does the standby light flash...b/4 pausing and repeating ?
Dec 20, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36XBR800 36" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Oct 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Emerson LC320EM8 32 in. LCD TV Logo
60 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
