Question about Brother XL-5340 Mechanical Sewing Machine
I do not have my manual and am unable to open to change the bobbin thread
  • 340 Answers
Ther's a manual available, free, from the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Hope this helps!
Posted on Oct 03, 2010
How can I open/clean hook system?
Unable to assist without knowing the make & model. Consult the owner's manual. There should be instructions re how to remove the bobbin to access the hook area. Check the maintenance section.
Feb 16, 2016 | Sewing Machines
How do I get rid of excessive thread on the bottom of the fabric. I think this is thread from the bobbin.
changing feet on the machine does not effect tension . only changing bobbin will do that and most times it will be because you did not insert properly .
Jan 28, 2016 | Sewing Machines
My stitch length is tiny and will not change
When selecting a stich, there's a button with a triangle with one edge pointing down. There you can select Needle Position and Stitch Length. --PDF manual, page 23
The thread tension has no influence on the stitch length. It just adjusts, where needle thread and bobbin thread 'meet' inside the fabric. A too high tension means, the bobbin thread is pulled trough the fabric and can be seen on the upper (needle) side. A too low tension means, the bobbin thread is not pulled through the fabric and you can see the needle thread on the bobbin side.
Jul 08, 2014 | Janome Memory Craft 9000 Computerized...
I am unable to load the bobbin so it doesn't create birdnests on the under side of the sewing, what may the problem be?
It is probably not the bobbin creating the nesting, it is the upper thread normally. Thread up with two different color threads to see which is the culprit.
Apr 13, 2010 | Husqvarna Rose
Bobbin thread showing on top, automatic tension
It is possible the jam threw off the timing and this will need to be fixed by a sewing machine tech.
Try one more thing first. Lift the presser foot - this will open the tension control so the thread can properly seat into the control.
Re-thread the machine.
If this does not help, back to suggestion # 1.
Mar 25, 2010 | Sewing Machines
Help, my mom is out of town.. I sew two or three stitches and the machine stops. It sounds like it is stuck. I have taken out the bobbin and it doesn't look like anything is stuck?
Get out the manual and start with maintenance so you can be sure the bobbin area is clean.
Now start at the beginning of the manual.
Read and apply as you wind the bobbin and place it into the bobbin case.
Thread the machine - again - read and apply.
Pictures and graphics are very helpful but don't always highlight some of the important steps.
CAN"T FIND THE MANUAL -
Remove the bobbin-case and clean away any thread the may have tangled there.
Make sure the thread is tight and even on the bobbin,
If this is a vertial bobbin/metal bobbin case, the thread winds from the bobbin clockwise and then through the opening on the side of the bobbin case and under the guide just above the opening.
Lift the needle to it's highest position and then lift the lever on the bobbin-case and hold it open as you insert the bobbin-case into the shuttle.
If this is a drop-in, horizontal bobbin, the graphic on the plastic lid covering the bobbin will indicate which way the thread feeds from the bobbin and through the guides.
Replace the needle, with the flat side of the shank facing the back of the machine.
Lift the presser foot and re-thread the machine. IMPORTANT - always have the presser foot up when threading.
Hold onto the thread end, lower and raise the needle to pull up the bobbin thread, Take both thread ends under the presser foot and to the back of the machine.
Place a double layer of fabric under the presser foot. Hold onto the thread ends and lower the needle into the fabric for the first stitch.
Press on the power pedal.
Mar 14, 2010 | Kenmore Sewing Machines
Unable to replace bobbin case back into machine
Here's how I do it. I hold the thread with my left hand, just like the thread wikk be pulled up. With the right hand pull the metal tab toward me, hold it open while pushing bobbin in and twisting. When bobbin stops turning and feels seated, then release the metal tab to lock. good luck!
Nov 18, 2009 | Singer Sewing Machines
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
Singer 57817 thread tension problem
If you have Increased the upper thread tension on your machine, try these solutions.
* Decrease your bobbin tension if your sewing machine allows you to adjust it. Consult your manual.
* Re-thread your bobbin, It may be threaded incorrectly.
* Reinsert your bobbin, It may be inserted incorrectly.
* Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both.
I hope this helps.
Sep 21, 2009 | Singer 57817 Computerized Sewing Machine
Threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Nov 07, 2007 | Janome Mini Compact
Brother XL-5340 Mechanical Sewing Machine Logo
64 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
