Question about Linksys WRT120N Router
Configure my linksys wrt120n with the cd but can't found the internet all wiring are okay
    Sergeant:
  • 231 Answers
1.Powercycle your equipment (unplug) Modem and Router
2.To ensure it is setup correctly the Ethernet cable should be plugged into the Internet port of the router
3.Wait 15 seconds and plug equipment back in
4.Check Firewalls Win XP: Start/Control Panel/Firewall/Turn off not recommended and try the internet
5.XP: Go to Start/Run/Type ncpa.cpl this will bring you to Network Connections/Double Click on Connection ensure the it is assigned by DHCP and it has a valid ip address it should start with 192.168.
Vista/7 Go to Start/Search Bar/Type ncpa.cpl and hit enter, right click on connection and hit properties. Uncheck Internet Protocol Version 6 and Click on Internet Protocol Version 4 and hit Properties. Ensure that Obtain and ipaddress automatically is checked as well as Obtain a DNS service automatically and hit ok.
6.Restart computer and Try to get online
7.Go to command prompt Win XP:Start/Run/Type cmd and hit ok Vista/7 Start/All Programs/Accessories/Right click on Command Prompt and hit run as administrator.
8.Type ipconfig /release and hit enter
Then type ipconfig /renew
9. Minimize command prompt and try browser
10. If still unable to access the internet open command prompt again and type:
1.netsh int ip reset reset.log
2.netsh int ip delete arpcache
3.netsh winsock reset
4.ipconfig /flushdns and restart computer
Posted on Oct 03, 2010
What is the security code for the WRT120N router
IF you don't know the password to your router you will need to reset the router by sticking a pin or toothpick into the hole on the back label reset and re-configure your router.
Dec 02, 2012 | Linksys WRT120N Router
Trying to configure my Linksys WRT120N router, but when I click 'Save Settings' I get an error message (324). What's wrong?
I think you can try upgrading the firmware on your router,
Connect the computer to the router.
Download the latest firmware.
Open the setup page of the router and upgrade the firmware.
After upgrading the firmware, reset the router and reconfigure it manually.
See How to upgrade firmware on Linksys router.
Watch video: Linksys router setup
Mar 27, 2012 | Linksys WRT120N Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
I lost internet connection from my compac presario CQ56 and my linksyswrt120n wireless router. Everything was fine the night before. The next morning there was no connection. I think it might be a...
You can try to reset the router and reconfigure it.
Press and hold the reset button on the router for 30 seconds. Release the reset button and wait for 30 seconds. Power cycle the router and reconfigure it.
Follow this link to configure WRT120N router without CD.
Jul 24, 2011 | Linksys WRT120N Router
I set up my WRT120N router. My desktop is connected to the internet with the provided ethernet cord, but my friend's macbook cannot connect wirelessly. He keeps getting a "timeout" message. ...
You Linksys wireless settings ie. SSID and encryption etc these settings are needed to configure the wireless card in the MAC so it can connect to the Linksys.
Dec 04, 2010 | Linksys WRT120N Router
I have a flashing icon on my WRT120N linksys router and when i connect my dsl modem to it, i have no internet connection. How do i fix this?
  1. check the line has internet service enable (telephone provider),
  2. check the microfilters on each telephone plugs
  3. check the dsl light stays always on. if not is a line/provider service problem.
  4. enter the router webpage.
  5. configure the user and password internet acess codes. (check the internet provider for your internet account)
  6. check the internet light turns on
Nov 06, 2010 | Linksys WRT120N Router
I reser my router but they ni restore default settings
since you already reset the router you can run the installation disk again and re-configure it
>>but if the cd will not work you can access the setup page of the linksys router.
just open an internet browser and type 192.168.1.1 as a default gateway
and if it will ask for a username and a password just leave the username blank and put admin for the password
>>and you can configure the router there
>>hope it helps..
Oct 16, 2010 | Linksys WRT120N Router
I just bought a wrt120n linksys router, i used the cd installation setup to configure it. Once i was done with the configuration, i can only get connection to the internet through wireless and not by a...
Hi Friend,
We need to configure the wireless and router settings manually. Wireless settings configured with the CD wont last for too long.
Turn on the router and make sure every wire is connected to its actual place.
At the back of the router there is a small RED/BLACK button, push and hold that button for 30 seconds. Release the button and turn off the router for 30 seconds. After 30 seconds turn it on and wait till the power light is steady.
1.Type 192.168.1.1 in the web browser and hit enter
2.Enter the username and password(password is admin and leave the username blank)
3.Click MAC Address clone which is just below Setup alongwith basic setup
4.Select the Enabled button and click "Clone My PC's MAC.
5.Click Save settings
6.Click Wireless and fill the sections as mentioned
Slect the Manual Configuration button(after selecting you will get a different page)
Network Mode-Mixed
Network Name-As per your choice
Channel Width-20MHZ only
Standard Channel-11
SSID Broadcast-Enabled and click Save Settings.
7.Click Wireless Security and fill the sections as mentioned;
Security Mode-WEP
Encryption 40/64 bits 10Hex digits
Key1-Enter 10 digit or 10 letter password(example-your telephone number) and click Save Settings
8.Click Advanced Wireless Settings and fill the sections:
Beacon Interval-75
Fragmentation Threshold-2306
RTS Threshold-2307 and click Save settings.
Turn off the router for 30 seconds and turn it on. you will be able to access the internet through cable.
make sure you put the internet wire(coming from the modem)to the WAN/internet port of the router and your computer to any of the four LAN p orts.
i hope this will resolve the issue.
Regards
Chiranjeet
May 27, 2010 | Linksys WRT120N Router
Linksys WRT120N Router Logo
293 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
