Question about Galaxy Radios DX-66V Base CB Radio
We are trying a radio check for a mirage 66 but the static only goes away when we turn the squelch all the way down and we can't hear anyone
    Guru:
  • 773 Answers
Sounds like you have a lot of interference. Could be something in the vehicle causing all the noise. Try it with the engine off. Also make sure the antenna system is correct. for example, coax good. antenna grounded. SWR low. etc.
Posted on Oct 12, 2010
Cannot receive info on weather channels
What model scanner? Where are you located? Make sure "squelch" control is turned to where you hear static, then turn it back just a little bit so that the static goes away; then you should be able to scan for WX channels if you have the antenna on the radio. Let me know more info to try and help you more.
Feb 21, 2013 | Radio Communications
I have a cobra 29 with echo, tweeked and tune. I can transmit strong and I hear those who speak to me but I dont have any static like you do with a new radio. Is this something I need to worry about as Im...
Make sure the squelch is turned all the way to the left, the RF GAIN is turned all the way to the right. The cobra 29 has a very good noise blanker, Turn the ANL/NB switch to off, You will probably hear a Lot of static, As long as you have a good ground on the radio and antenna, and your SWR is 1.5 or lower, you need not worry about static.
Oct 05, 2012 | Cobra 29 LTD CB Radio
Can not get static out of radio i have a cobra 29 with weather channel the squ knob seem 2 b not working sometimes can u help me
Turn the squelch down, and the RF gain all the way up.
You need to realize that some times, there is not a lot of noise out there. Right now lately there has been due to skip. But it does die down. When you hear a lot of noise for a while, then it goes away, it messes with your head. You don't hear anything, but that's because its quite out. I would test it by talking to some one on the radio. If you can hear them just fine even though you don't hear a lot of static, then its just quiet out.
Jul 23, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
How can i hear what they are saying without that awful loud sound when they arent saying anything. cause when i turn the volume down i cant hear what they are saying
Turn up your SQUELCH button when no one is talking until the static noise just goes away.
Now your set will remain quiet until someone talks.
If you set the squelch too high it will also cut out the people talking, so always try to have it set just slightly above the background static level.
Good luck.
Apr 15, 2011 | Uniden BC350C Base Scanner
When i transmit if the other vehicle is anything over a mile away they get a lot of static. I can receive them clearly at up to 5 miles. What do I do to get better transmission? I have a K40 antenna...
Well if they are not hearing you over a mile but you hear them over 5 miles that is a good indicator that your antenna is working properly but your radio is not getting out there. First go ahead and check the TX knob. Turn it all the way to the right so you modulate as much as the radio will allow. Next turn the squelch knob all the way to the left until you hear static and then turn it to the right slowly until the static noise goes away. Some don't mind the continual static but I like to squelch it out. The TX being turned to the right will allow your radio to work at full capacity. If you still don't get reports much over a mile then you can try a power mike to help you out a bit. Your microphone could have seen it's better days and can for sure mess up your transmit. Make sure your SWR is low 1:1.5 is the goal not to exceed 2. If all that checks out then have it peeked /tuned and aligned by a tech. Good luck to you.
Feb 06, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
My Squelch on my Cobra C.B isnt working anymore, Does that mean anything or do i need a new C.B?
It means either the knob or something in the squelch circuit has gone bad. Doesn't mean that you cannot use the radio, you will just hear static all the time when no one is talking. If the static bothers you, you can always back the RF gain down a bit. That will quiet the noise, but lower you receive range. meaning you won't hear as far away.
Nov 14, 2010 | Cobra 19 DX IV CB Radio
Having major issues with programming my bearcat bc60xlt-1
You'll need to program the radio frequencies into your scanner before it will scan . For a list of frequencies in Anoka County CLICK HERE .
For specific programing instructions for your UNIDEN refer to your owner's manual. They will give you a step by step instruction on how to program the frequencies into your scanner memory (If you need a manual, CLICK HERE
...be sure to select the scanner option on their pull-down menu.
THEN when you have the radio frequencies stored into your scanner, you'll be able to press scan and away you go.
Be sure to adjust the squelch just high enough to eliminate the static...turn the squelch counterclockwise until you hear loud static, then turn Clockwise just enough to silence static...
Let us know if you still have trouble.
Jul 20, 2009 | Uniden BC60XLT-1 Handheld Scanner
Uhf radio cb tranciever
Hello Are You using the correct antenna?,when you turn the squelch down do you hear static sound?, are you using squelch codes? if it is just a CB radio that works on Citizen Band (11 Mts) this radios does not have squelch codes.
Let me know the brand, model of the radio.
Dec 18, 2007 | Radio Communications
Radio Mic
Check the squelch on your radio thats not recieving. If there is a monitor button ( when pushed you will hear static) try pushing it.. then get someone to call you so you can check if you can hear them. On these radios you have 2 types of squelch....1 is called carrier squelch.... it basically opens when there is a strong enough signal. This lets you only hear strong signals and "squelch out" the distant ones and background static. The2nd. is "tone squelch" ... with your radio they are often called privacy tones. If you have 2 radios set with the same privacy tones you will only be able to hear each other... only radios that are transmitting with that privacy tone will be heard on your radio. Its a high frequency tone that can't be hear by the human ear that gets "embeded" with the transmitting signal. The recieving radio hears it and opens the squelch. So... if the radio thats rxing (recieving)your signal has its squelch set for just carrier squelch it will hear any signal thats strong enough to break the squech open.... basicaly any radio within a certain range. But if your radio (one with problem) has its squelch set for privacy tones you will not hear any other radios except the ones set with the same privacy tone.... the squelch will not open until it gets a tx signal with the right tone.... so if the txing (transmitting) radio is not using tone squelch but is using carrier squelch.... and the rxing radio is set for tone squelch... the rxing radio will not hear it. With tone (privacy tones/codes) squelch you need a tone to open the squelch and then the audio can be heard... with carrier squelch the squelch will open if ANY radio is within a certain range. Check the squelch setting on the problem radio... it could have a privacy tone set. Try pushing in the monitor button so you can hear static ( you want to hear everything including static) on both radios... tx on one radio at a time and listen if it can be heard on the other with the monitor button pushed. If you can't hear any audio when the broken one is transmitting then it COULD be the mic.... if you can hear both radios with the monitor button activated than the radios are txing and have tx audio and are working... if thats the case its the privacy tones that are the problem. Take care
Sep 12, 2007 | Garmin Rino 120 2-Way Radio
Motorola FV500 2 way radio can send/cant receive
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Aug 09, 2007 | Motorola FV500 2-Way Radio
Galaxy Radios DX-66V Base CB Radio Logo
54 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
