Mouse pad lock so the pointer is not moving. everything is working perfectly
Hold function (Fn) key and press f7... it will resolve the issue
Posted on Oct 25, 2010
Mouse pointer jumps when moving it on screen.
If you are not using a mouse pad, try that. Using the mouse on reflective or glass surfaces. Try another mouse to see if it has the same issues. Check your mouse settings in control panel to make sure everything seems ok. Update mouse drivers. Finally, you can try to uninstall / reinstall the mouse.
Nov 13, 2013 | Gateway Computers & Internet
Mouse stopped working on Compaq Presario CQ57
The Touch pads the Mouse Pointer uses is pressure sensitive and sometimes without warning WILL fail to work I own a CQ50 And Have a On Off Option for the mouse pad Yours does not Apparently it Is a bad sensor If you have a warranty send it in If not best suggestion for you is buy a USB mouse and use it Otherwise trying to have it replaced without a warranty can be costly.
Feb 03, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
Mouse wont move
Are you referring to the mouse pointer when using the touch pad? To isolate the problem, try to use a USB mouse and see if the pointer will move. If the USB mouse works, then the touch pad could be disabled.
Refer to the user manual of the laptop and see on how you can enable the touch pad.
If same problem occur even though you're using a USB mouse, contact the manufacturer of the computer for second opinion or repair.
Good luck and have a great day!
Feb 08, 2010 | Dell Inspiron 6400 Notebook
When mouse pointer is set to go to default box it does a runner!
check the mouse sensitivity settings under control panel.
Oct 06, 2009 | Computers & Internet
Mouse
you might have locked the pointer just press the button on muse pad that will make it work ,it is posibilty that your system might not be having synaptics control aplication or that might be corrupted
Sep 01, 2009 | Acer Aspire 5315 Notebook
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Cant get Pointer to move
It's WIRELESS. The receiver is powered by USB. The mouse needs batteries. AAA in most cases! If batteries test ok in a remote control...they should have enough for mouse.
Nov 12, 2007 | Dynex DX-WOM20 Mouse
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
