Question about Avery Design Pro 5.0 for PC
I can make CD labels but they will not print to my color printer. They will print to my black & White laser priner. I have tried both issue 4.0 & 5.0. What could be wrong?
  • 1 more comment
  • user85375 Oct 03, 2010
    My color printer is an HP Photosmart C-4680. I already had it set as the default printer. I can print any other document in my computer to this printer. Labels I create on Avery Design Pro software will not print on this printer but will print on my HP Laser printer (black). Do you have another suggestion?
    Thanks,
    Nichols
    ID 240 023 689
    Password 4113
    Thanks!
    President:
  • 2,777 Answers
It means the printer selected by the software is the wrong one, it usually just uses your "default" windows printer. What you want to do is make sure the cd label software is closed, then click START, go to CONTROL PANEL, in there you will have Printers or something similar. It will pull up a list of the printers on your computer. The one with the green check mark next to it is the default one, which sounds like your black and white laser. Your other printer will be listed there as well. With the mouse - right click on the color printer listed, and go to SET AS DEFAULT. This will move the check mark to this printer, which is what we want.
Once you have this done, re-open the label software and you should be printing to the correct printer.
Thanks
Tim
Posted on Oct 02, 2010
  • Tim Grayson
    Tim Grayson Oct 03, 2010
    That is very strange. There must be a setting in the software to change the printer to the color printer. Go into the program, go to FILE and look for settings / preferences. It may be under EDIT as well. There is definitely a way in the program to specify the printer. If you want I can take a look at your screen, if you want to do this, download this little file:
    http://www.teamviewer.com/download/TeamV...
    Open that file up when downloaded, it will have an ID / Password.... reply back to me here soon if possible, with the ID and Password, and leave that window open. I will connect to your screen and get it figured out for you.
    Thanks
    Tim
My canon iP90 prints in color but when I want to print a picture it comes out in black & white what should I do to get color pictures
on you pc go in start pinter settings. right click on the priner
go in properties. you will find there a option for gray scal or colour.
Oct 14, 2011 | Canon PIXMA iP90 InkJet Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
How do you print only in black & white to a dell 5110cn laser printer? the printer is currently out of magenta toner and will not print. do you need a magenta toner cartridge in order to print to this...
go into printer and faxes and and right click on your printer and and go to printer Prefereces you should see either print in black in white or gray scale
this should fix it for you
Good Luck
Happy Computing
Jan 09, 2010 | Dell 5110cn Laser Printer
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Dell 3110cn won't print color. It shows in color on the print preview window, but comes out black & white
There's a setting in the driver that makes it print black (OK - grey scale) only.
Try that.
Jul 10, 2009 | Dell 3110cn Laser Printer
Trying to print in black & white only
THis option is in the printer driver.
under Printing Preferences
Graphics
Output Color
Change this to BLACK
Jul 01, 2009 | Dell 3110cn Laser Printer
Kodak ESP 5 runs out of ink after about 40 pages of standard text black & white documents. Also the color ink level is dropping, but no color is being used (the printer is set for black & white...
As far as the quantity of black & white - to get more out of it - go to start menu.. Click on on settings,, then printers,, Right click on the ESP 5,, click on printing preferences,, then clcik on draft,, then click on (at the top) advanced,, click on black & white.. Then click on apply then ok..
Now - every time you print it will be in this mode.. If you want to print in color - you will have to choose that each time..
For you black & white docs - this will print faster & use allot less ink..
As far as your color issue & puddling - It could be the printer head.. If it is new enough - call Kodak & maybe get a replacement.. If to old - maybe keep the color cartrige out and caped with the plastic caps until you need to print color.. Snap it in & out as needed..
I hope this helped..
Jun 11, 2009 | Kodak ESP 5 Printer
Why does the Samsung clp-510 color laser printer keeps defaulting to black and white print out when printing color images?
Well one thing you should do is when your printing something out before you print make sue that you have selected color not black and white because most printers have a default setting to use black and white. Also make sure that you have color ink available to print.
Apr 09, 2009 | Samsung CLP-510 Laser Printer
Dell 5110cn Color printing only printing in black and white
check in the printer properties and make sure on the color page that "print in grayscale" is not selected. This option will make the prints all in black (grayscale)....
Dec 31, 2008 | Dell 5110cn Laser Printer
Printing on CD labels seem to ruin fuser in Phaser 7300
Probably the labels have a slight plastic fiber or coating in them and is getting a coating on the heat roller.
Here are part numbers of the correct CD labels you can run without a problem.
Xerox Matte Coated CD Labels, 6-Up, 11x17
Reorder 3R12373
75 sheets per box
spacer.gif Other items to consider: Return to Top spacer.gif Item Color Price/Unit Quantity Xerox Gloss Coated CD Labels, 6-Up, 11x17
Reorder 3R12372
75 sheets per box
Item Color Price/Unit Quantity Xerox CD-ROM Glossy Coated Labels, 4 x 7
Reorder 3R6322
50 CD-ROM Labels, 25 Sheets per carton
White - Glossy Coated 1-9 Box $17.44 10-49 Box $16.90 50-99 Box $15.65 100+ Box $14.89spacer.gif
Feb 22, 2008 | Xerox Phaser 7300DN Laser Printer
Avery Design Pro 5.0 for PC Logo
111 people viewed this question
Top Avery Computers & Internet Experts
Donna Sander
Are you an Avery Computer and Internet Expert? Answer questions, earn points and help others
