Question about Sony KP-51WS500 51" Rear Projection Television
My tv turn on then after 2 minute it become green ang turn off by itself what so i need to replace
  • samsmh Oct 03, 2010
    some poeple say its the d board is that right
  • 10,594 Answers
It is symptom of defective Green Picture Tube that needs to be replaced. (technical name is Green CRT)
This is rear projection tv that has three picture tubes (red-green-blue) inside to project color picture on front screen of tv,
Picture tube replacement in rear projection tv requires lots of adjustments and professional would be good to perform that so contact local tv repair shop for repair estimate.
Let me know if you have additional question.
Thanks.
Posted on Oct 02, 2010
  • Shahid Electronics
    Shahid Electronics Oct 03, 2010
    D board looks just fine as it is deflection board and if D board got bad for some reason, tv wont even show picture for 2 minutes
My sharpe tv won't turn on the green light is on but it won't start and you can't turn it off or on with the remote or button. You must unplug it for the green light to go off.
Please attempt to bring up an internal image on the screen by pressing Menu button on TVs remote, and on the TV panel itself. Do the same using the Volume button to see if the volume bar appears. If they appear, check the cords of the sources connected to the TV; make sure they are secure, and not loose.
If doesn't appear going to need a circuit board replacement.
Nov 09, 2015 | Sharp LC Televison & Video
Philips TV Model 44PL9522/17. When I fist turn on the TV, the color red turns green and then after an hour or two, it becomes normal. Now the TV will turn itself off after 10 minutes. When I turn it back...
Greetings,
Power supply cannot sustain energy to the whole system.
If you know electronics, check the power supply section.
Else, have it serviced by a qualified technician.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 29, 2008 | Philips Televison & Video
Sanyo tv model # st-21ys2 defective system ic
sir may ginagawa akong tv ang trouble nya. pag on mo ng tv after mga 2 to 3 .minutes nawawala na ang sound tpos pag pinatay mo at pag plug mayron uli sounds tpos nawawala uli sound buo ang i.c sanyo st 21ys2
Apr 15, 2013 | Televison & Video
My panasonic pt-521cx16 starts, green light flashes, then shuts itself off again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Jan 22, 2018 | Panasonic PT-52LCX66 Projection Television
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Picture is completely out of alignment, went to do
It means the convergence IC gave up already ang needs a replacement. And also check the 5A picofuse in the power supply.
Dec 28, 2009 | Mitsubishi WS-65869 65" Rear Projection...
TV won't turn on even though it starts green, then goes off
Although my tv still does the "turn green and turn off" thing, I simply unplugged and repluggd the tv. After I did that, I pushed the "ON" button on the tv itself, unplugging and replugging the tv until it finally came on. I think the "instant warm-up" switch is going out.
Feb 18, 2009 | iLO 3200 32 in. LCD Television
Mitsubishi WS 65513 turns itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 05, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Patay sinde
Your concern is that the TV turns itself off. This could probably be due to any of several possibilities:
1. cold solder or loose connection, may maluwag na koneksyon sa loob o mayroong hilaw na hinang. Kailangan lamang itong painitan ng soldering iron upang muling manumbalik ang kinang at tamang pagkakapit. May mga pagkakataon na maaring maluwag din ang ACplug sa outlet;
2. heat induced - may pyesa na nag-iinit at tumitigil sa pag-andar pag mainit na. Kadalas ay mga capacitor, transistor or regulator;
3. low supply of the AC mains - mababa ang kuryente, maaring ito ma-check sa pamamagitan ng isang Voltmeter. Kung mababa nga, maaring gumamit ng voltage regulator kagaya ng sa mga computer;
4. timer - may mga pagkakataon na mayroong timer kaya kusang nag-switch off anf TV makalipas ang takdang oras;
Of course repairs would involve knowledge and familiarity with electronics circuitry and components, use of a DVM and a soldering iron. Should you be uncomfortable performing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Sharp 25N-M100 25" TV
Sony KP-51WS500 51" Rear Projection Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
