Question about KitchenAid KERC607 Electric Kitchen Range
Kitchaide KERC607 oven not heating, broiler not turning on
    Sergeant:
    Champion:
  • 351 Answers
May have bad element
Posted on Oct 03, 2010
  • bethg5293 Oct 03, 2010
    How would one fix that?
  • sparks194520 Oct 04, 2010
    replace element
Is the bottom part of the double oven the broiler?
Most likely. The broiler is the central source of oven heat.
Dec 15, 2017 | Ovens
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Oven wont heat broiler wont heat
is this a gas or electric range. If it is gas it sounds like a flame sensor is not working. The oven will try to fire up, but if it does not sence a flame, it will shut off again to keep the range from filling with raw gas. Also the easy one, is the gas turned on?
Aug 31, 2012 | Kitchen Ranges
Oven not generating enough heat
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Mar 15, 2011 | KitchenAid KERC607 Electric Kitchen Range
Broiler works oven doesn't heat
Based on your description, the igniter is dead.
The broiler and the oven heat each have their own igniter. Look for the characteristic glow when the oven is turned on. If it is not visible, then you will need to replace the "OVEN" igniter...
Google the stove model for repair parts and locate the igniter. Not too hard to replace... directions are packed with the new igniter...
Jan 08, 2010 | Maytag MGR5750 Gas Kitchen Range
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
Broiler element won't heat. oven won't hold
check the broiler element for "Hot-Spots" where its dis-colored and is ready to break
Oct 07, 2009 | Whirlpool RS696 Electric Kitchen Range
Oven and broiler: no heat
Flipped the breaker switch! Although we had looked at the breaker first thing, and it was not flipped off, plus everything else on the range was working: we found out it is actually a double breaker, with one half controlling just the oven, and it can be just partially flipped and you don't notice it. So as soon as you toggle it off and on again, you are back in full power.
Apr 08, 2009 | Kenmore Kitchen Ranges
Our Electric Amana Self Clean Oven, the broiler is not working? Help! The oven and stove top work just fine, but when we go to turn on the broiler the broiler doesn't come on, the selection buttons all...
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
Feb 21, 2009 | Amana ARGS7650SS Gas Kitchen Range
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
KitchenAid KERC607 Electric Kitchen Range Logo
188 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
