Question about Maytag Neptune MDG5500AW Gas Dryer
Dryer does not stay hot. after you start dryer it will only stay hot for about 2 minutes. the lint trap in the dryer is clean and as far as i can see down the pipe is clean.
  • tothran76 Oct 03, 2010
    it sounds good. i will give it a try and let you know. i could not access the accept button so that is why i am seading you my response this way.
    President:
  • 1,554 Answers
The problem is the gas valve solenoid coils which seem to work fine when cool but fail when get heated. The only viable solution is replacing both solenoid coils located on top of the gas valve assembly. Raise the top cover and remove the front panel to access and replace the solenoid coils.
Front Panel Removal
Posted on Oct 03, 2010
  • Jahn27
    Jahn27 Oct 03, 2010
    Feel free to give an update.
Forgot lint trap, dryer making noise immediately after. Cleaned vent and blower wheel and housing- still making noise. What else could it be??
If its like a grateing metal on metal it sounds like the rear bearing has worn through which is quite common.
hope this helps a bit
Jun 24, 2016 | Dryers
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Hi super capacity dryer - tumbling ok, apparent hot air when door is opened, but clothes still damp after about 90 minutes of drying time..also no visible lint in lint trap..? any suggestions? thank you
ventilation problem,disconect hose from back of dryer make sure lint trap is clean turn dryer on clothes should dry,if they do your is bad or vent to house is stoped up
Jan 23, 2011 | Whirlpool Dryers
I CAN HAVE MY DRYER ON THE HOTTEST SETTING AND IT GETS HOT BUT TAKES LIKE 3 TIMES THROUGH A CYCLE TO DRY MY STUFF
I would first pull the exhaust hose or pipe off and check for blockage or a kink. If its getting hot then its probably an air flow issue. Also make sure the lint trap is clean. Sometimes you can get the crevice attachment for a vacuum down in the lint trap area far enough to clean any excess lint out. Check where the dryer exhausts outside for a blockage like maybe birds nest or bees hive. I hope this helps.
Aug 13, 2009 | Whirlpool Dryers
Fisher and Paykel electric top load dryer
Dd you try to unscrew the larger lint trap underneath the lint cup collector. My serivce person showed me how to do this and after a year I cleaned it out and was surprised how much lint was caught in there. My dryer was not heating and drying quickly, this helped the problem.
Sep 11, 2008 | Fisher DEIX2 Dryer
Dryer stays hot hours after using it
The heater has failed and/or is shorting to the case. Remove the rear panel. The heater is on the right side, attached to the heater housing with two screws.
Jun 25, 2008 | Kenmore 62802 Electric Dryer
Roper dryer
YOU HAVE A VENTING ISSUE WHICH CAUSE SLOW DRY STEP1 REMOVE LINT FILTER AND CLEAN WITH HOT WATER AND SOAP STEP2 MAKE SURE YUO'RE NOT CRUSHING YOUR VENT HOSE BY HAVING DRYER PUSHED TOO FAR UP AGAINST WALL STEP 3 CHECK OUTSIDE VENT TRAP IS NOT OBSTUCTED BY LINT IF THESES STEP DOESN'T WORK HAVE PROFESSIONAL CHIMNEY SWEEP INSPECT AND CLEAN VENTS
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 28, 2008 | Dryers
Longest 6 minutes ever
I wiped off the two rows of sensors located behind the lint trap inside the drum. Now my dryer shuts off at 0 minutes. The clothes are still a little bit damp so I let the dryer run for 10 more minutes. Try it before replacing the computer board.
Apr 03, 2008 | LG DLE2514 Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
70 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
