Question about Car Audio & Video
Need to know where the remote wire hooks to on the cd player
  • 400 Answers
Is it for your amp???? If so (considering you have an aftermarket stereo), find the blue blue. Sometimes it is blue with a white line.
Posted on Oct 02, 2010
I dont know how too hook up a remote wire for a amp for subs
there is a blue wire on back of deck with white stripe thst is the remote hook a wire to that and run to amp plug in to remote on amp and there you go i hope this helps you
Jul 10, 2011 | Pioneer DEH-P700BT Car CD Player
When i hook up my amp my speakers wont play music? ive hooked up my rca cables up but i ont know if you hook it up to the input or output frum the cd player?
you rca hookup, back of cd player is rca out, at the amp it is rca in, make shure you hook up blue remote wire, also make shure you have a good ground if not amp will not turn on. if you run wires make shure you run power wire down one side of car and remote and rca down the other, This will keep all motor noise out of system.
Oct 07, 2010 | Audiofonics Car Audio & Video
My boyfriend hooked up my speakers in my car to my cdx-gt200, now my cd player wont even come on. He never touched any of the connection wires for the player. At first he could not find the remote turn on...
change the fuse behind the system.
"so he hooked it up to the left front speaker wire, then found the remote turn on wire and hooked it up to it." will have burned the sound system or not. remove the new installation, test it, reinstall, test again.
Jun 01, 2010 | Sony XPLOD CDX-GT200 CD Player
Amp promblems
When hooking up an amp a remote wire has to be ran. It is possible to jump the remote from the power wire, but if you do this the amp will not shut off unless you disconnect it. If this is done on your amp your battery will continue to die. Also, most cd players have a remote connection. Check to see where your amp remote is running to.
Jun 22, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Where does the blue/white remote wire hook to.
Hi, I'm not sure I understand your question. It sounds to me like you haev a 1989 GMC truck, and you've installed a JVC CD player in it. The CD player has a blue and white wire coming out of the back, and you would like to know where it goes and what it does. Is that right? If so, then the blue/white wire labeled "Remote" coming out of your CD player is intended to turn on an external amplifier or some other "remote device". If your truck has a power antenna installed, this would be the wire that tells your power antenna to extend and retract. Many stereos have two of these wires - one for the power antenna and one for an amplifier. If you don't have an amplifier or power antenna, you don't need to do anything with this wire, just leave it alone and make sure it doesn't touch any bare metal behind the radio. Hope this helps.
May 16, 2009 | JVC AM FM CD DET FACE CAR STEREO
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32492d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock01.pdf Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
http://www.allfordmustangs.com/forums/attachments/4-6l-tech/32493d1188791176-2003-mustang-fuse-box-diagram-2003-enginefuseblock02.pdf
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Car audio
on the back of he cd player is the wire harnest there should be a SOLID blue wire on there take the remote wire connect it to that and run it to your amp and put it where the amp says remote. there is an easier way you can hook up your power to the amp then take the remote wire and just run it directly to the power wire on the amp you should only need a couple inches of wire and it will work fine
Jul 10, 2008 | Kenwood KDC-MP335 CD Player
Car stereo
its pretty simple, the remote wire is used to tell the amplifier that the cd player has came on. once the cd player has came on, the amp then comes on. simply take a light tester that has a sharp tip, turn the ignition until the cd player comes on, and start testing all of the wires. when you hit a wire in which the light tester says there is power flowing through it, turn the cd player off. if the light goes off with the cd player, you have found a wire that is suitable for a remote wire. dont know how to use a light tester? http://www.bcae1.com/testlite.htm
Jun 18, 2008 | 1996 Pontiac Grand Am
SONY CDX-M8800 STEREO
Red (accessory wire)- goes to hot wire that can be turned off.
Yellow (constant wire) goes to your cigarette lighter
Blue/white is your amplifier remote turn-on wire.
Probably have green and green/white- brown and brown/white-white and white/black, and another color for speaker wires.
You can hook one pair up to your cd player and find out if it's hooked up to the right speaker channel.
Orange (remote antenna) wire.
Apr 20, 2008 | Sony CDX-M8800 CD Player
No remote from Cd player. What to do?
thats a car dvd player right what u would do is to take the back of the unit and look for the female ends of rca's on the unit that they will say rear out put hook them up and run them to the amp and i dont get what u mean about the remote wire but let me no if that helps
Apr 04, 2008 | Jensen A600HLX Car Audio Amplifier
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
