Question about RCA 27R411T 27" TV
Top half of my RCA TV is black with thin lines, and no picture and TV is only 3 years old! Ony the bottom half has any picture. It did this about four months ago and lasted for about two weeks, but then suddenly corrected back to normal one day without me doing one thing to it. Now the problem has come back and it's been this way for about five days. I do not want to buy another TV if there's something that can be done to correct this one. Thanks
    President:
  • 2,992 Answers
This is usually caused by bad solder connections to a part called the vertical output integrated circuit. A TV service shop (if there are any in your area) could go over the connections, probably for their minimum labor charge. (I've been out of shop service for a long time now, so I have no clue what a typical labor charge might be. Sorry!) If other parts turn out to need replacement, which sometimes happens, they could give you an estimate for the repair.
Posted on Oct 02, 2010
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
RCA serial 137651043, model P52939, 55 inch tv.
Half black? top/bottom or left right?
The set is rather old--a old trick to use is to connect a fan to the rear of set with the back off--it may extend the life of the set and give you some more use out of it.
I have seen a lot of these sets and never one with the problem you describe. If only a picture top or bottom is missing it may be vertical or if you are seeing what looks like a full picture with top or bottom black it is a Blanking problem--may not be easy to find...........
Apr 25, 2012 | RCA P55000 55" Rear Projection Television
Old Panasonic tv approx 10/12 y/o? -Model TX-28CK1L Serial no ND-0360158 Last night 50% of screen from top to middle "blacked out"--half picture still visable on bottom half. Very bright thin...
The main coupling capacitor feeding the frame scan coils has failed or the output stage on the frame stage has failed due to dry capacitors or dry joints.
Fault finding and components are not a problem and yes it is very repairable. Any technician that knows how television works can repair this standard frame output stage.
I hope you find a good technician.
Dec 30, 2010 | Panasonic Televison & Video
There are vertical 1" to 2" black lines that come and go. They are on the top half of the screen only. Also, the TV takes 40 min of flashing before the picture comes on. Our TV is about 5 years old. ...
Yes,This tv have two problems.One is the power supply board have dead capacitors,need it to replaced,the other is the vertical lining board on the bottom near the speakers need all the old lining to resolders.The shop will cost u $ half to repair,it to buy a new tv.
Apr 04, 2010 | Toshiba 42HP84 42 in. Plasma HDTV
Picture narrowed in. black lines on sides
check and or replace the following :
q551
d830
d825
r818
repair must be done by qualified tv pesonnal
Jan 22, 2009 | Panasonic CT-32D12D 32" TV
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
Old tv only shows half picture
it looks like some caps are bad in the set.
Have it serviced by a TV repair shop
Aug 02, 2008 | Televison & Video
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA 27R411T 27" TV Logo
78 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
