Question about Panasonic NN-T664SF Microwave Oven
Is there an internal light in the NNT664SF - Panasonic NN-T664SF Microwave Oven
Yes, there is a light on the right hand side of the microwave (looking at the control panel). It is located directly behind the control panel and may be seen with a flashlight looking inside the door through the perforated metal housing. Four special hex-with-stem screws must be removed from the cover to access it, along with one standard Phillips head screw on the side. Once the screws are removed you must slide the cover toward the back about 1/2" before it will be able to tilt up and be removed.
For safety reasons make sure to unplug the unit and allow it to discharge before removing the cover. Also make sure to not touch anything you aren't intending to work on - it could be carrying power from the capacitor, which is like a battery, and might not be discharged while you are poking around inside.
I am currently seeking out a replacement lamp for mine. I could not find one at any of the local hardware stores as this has a proprietary base and the bulb is not removable from the base. I will be looking on ebay and elsewhere.
Posted on Apr 16, 2011
  • mmaxsoj Apr 16, 2011
    I found the part at panasonic parts and accessories service center. It is part number F612E5Y30AP.
My ramtons micro wave does not have it internal light working,whats its the problem
Does it work?
Change bulbs in Microwave sometimes is tricky
See if you can get the manual for your device from here and chek if say anything about internal light
Jun 30, 2015 | Microwave Ovens
Frigidaire gallery microwave light stays on and internal fan stays on
Good Afternoon Friend, thank you for your post!
I see that the internal light and fan continues to run on your Electrolux microwave with the door close. This sounds like the issue is related to a faulty door switch. I am fairly confident that an authorized service agent will be able to restore your microwave to its normal operating condition. You can often locate a qualified service technician on the manufacturer website. Hope this helps! - Z
May 20, 2014 | Microwave Ovens
Unit went dead. No fan, display, light, oven. Is there an internal fuse or reset?
There is an internal fuse. Be careful high voltages present even if the microwave is unpluged.
Good luck
Jan 03, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
My new panasonic microwave model NN ST 340w has the internal light on when I heat up food. However when I open the door to put food in or take it out, the internal light does not turn on. What can I do?...
Your oven light is busted or damaged. You can buy the replace at the any electronic shop. Just open the top cover then you will see the light you will going to replace
Aug 15, 2011 | Panasonic NN-H664 Microwave Oven
All instruction manuals missing (lost in flood). Also internal light does not work
check http://www.manualsonline.com/
enter manufacturer and model number
for internal light, check the bulb, probably needs replacing
Nov 05, 2009 | Samsung Microwave Ovens
Internal light does not come on
Relay RY1 on the control circuit board has probably failed.
It's the relay closest to connector CN1, the 7-pin connector.
Have you had trouble with the cooktop lights of hood vent exhaust fan recently?
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number 721.62644200) for more information & help or see our Web site.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Feb 14, 2009 | Kenmore 62622 Microwave Oven
'Samsung smh7174wc' will not cook
It is probably more than a fuse which has gone on the microwave and because of the lethal voltages involved with this appliance plus the real risk of a damaging leak unless you have a microwave leak detector and a technical background i would advise finding a qualified technician. Good luck.
Jan 18, 2009 | Microwave Ovens
My microwave quit working
You have obviously damaged the circuitry. Service is expensive. Unless the unit is under warrantry my advice is to replace the oven. The newer ovens are very reasonable and have great features. Check Home Depot.
Ray
Dec 31, 2008 | Maytag Microwave Ovens
Kenmore 363.6367 internal light doesn't go on
I had the same problem! I was soooo frustrated! But, when my brother came to town, he took off the grill on the top of the micro hood, took out a few more screws, a plastic screen, another screw in the metal cover for the light and then reached in with his fingers to pull out the light bulb, we replaced it, then re-assembled it. It did take us about 30 minutes to do the job and you will need a phillips screwdriver, and a phillips screwdriver drill bit thing, but we were able to do it. I love having the light in the microhood again.
Dec 09, 2008 | Kenmore 63672 Convection/Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
