Question about Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725
We want to know the contents of Kleanogik freezer frost remover, There is no listing of this on the size of the bottle.
  • 316 Answers
If you have frost in the freezer, I hate to point out the obvious, but if you dont resolve the cause of the frost buildup, you will only waste your money removing the frost, only to have it return.
Posted on Oct 05, 2010
What tool do I need to remove a kenmore upright freezer door
A Torx bit for a power screwdriver or a Torx wrench size T20 or T15 probably.
Aug 05, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire frost free contents are thawing
Check your t'stat setting. If it is older than 10 years it is probably the compressor. As cheap as they are now, you would be better off with a new one. Labor and compressor would run an easy 200 dollars. Then you would looking at other things breaking after that.
Jan 29, 2013 | Frigidaire 17 Cu. Ft. Frost Free Upright...
My freezer works but not freezing
Could you please list a model number with your request for assistance? If I cannot answer your request just posting a model number moves customers to the top of the list for solutions. You refrigerator model number is most times found around the fresh food compartment door frame.
The most likely reason the freezer is not freezing as well as befor are the defrost components. Can you see a layer of frost building on the rear wall of the freezer? An example of this is found HERE Signs Of Defrost Failure and if you have these signs the evaporator behind the rear wall of the freezer wil look like this=> Evaporator Covered in Frost Due to Defrost Failure Let me know if the fans in freezer and under the refrigerator are running. Also if you don't have these signs the compressor may be short cycling due to a defective start relay, run capacitor and overload. Let me know and I will be here to answer your questions, Thanks Sea Breeze
Nov 21, 2012 | Freezers
Can you tell me how large (in cubic feet) this freezer is?
Is this a trick question? It is 20.3 cubic feet according to your question. This may be the capacity or the size of gross measurement ... you have not indicated.
Please ask the actual question you want to know ...
Thank you
Mar 22, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice in the bottom of freezer
Greetings,
the drain is clogged most likely...remove lower shelves, baskets, remove rear panel if self defrosting.. find the drain hole and use a hair dryer or hot water to defrost ice..once the surface ice is off...you will need to make sure there is no ice in drain tube going down under freezer. use a squeeze bottle with hot water and force it into drain. do this repeatly until water runs free down drain....Bruce Denton
Jan 09, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frosts up at front then food starts to defrost
It would appear to me the system has a leak. Allow me to explain. When a fridge/freezer is "lo" on gas it causes the compressor to run far longer than usual. As a consiquence the motor overload shuts it down, potentially for a very long time, hence the contents thaw. The major clue to this a frost pattern on just one wall. Have a tech visit to confirm, but I suspect you'll be out of luck as far as a repair goes. Chest freezers are not easy to repair "lo side" leaks, which is likely what you have, because the evap. coils are in the walls. sorry, but I hope that helps in some manner. good luck
Sep 28, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
I do not have a manual so I don't know how to defrost it
Look for a white plastic plug in the floor of the freezer, about the size of a quarter. Remove that. Take the front grill off and feel underneath for a plastic hose (one end connects to the drain hole, the other end you can catch defrost water in using a shallow pan). Use a hair dryer to melt the frost (with the freezer unpluged)
May 31, 2009 | Frigidaire Freezers
Frost free freezer
Hi, It sounds like the defrost drain is plugged. UNPLUG the freezer. Remove the rear panel and you will be able to find the drain hole and remove the ice. Once you get the iceout of the drain. try and fluxh it with hot water (A baisting serigne works great). Sometines they plug up with duse from underneath. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Red light on not cold enouth
The red light bis indicating that the temp is too high, if you can ,turn the thermostat to a colder setting, if this makes no difference, then you have a serious problem, you will have to call an engineer.
Plz rate this solution,
Thanks.
Dec 06, 2008 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Sep 15, 2008 | Freezers
Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725 Logo
310 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
