Question about Olympus FE-230 Digital Camera
Lens seems to be jammed . tries to open but just keeps cycling, open and close
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Olympus service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 03, 2010
CLP-320N KEEPS TELLING ME TO CLOSE DOOR...ALL THE DOORS ARE CLOSED
Most likely you should check the 'door open switch', probably its broken.
Apr 24, 2014 | Samsung CLP-315W Laser Color Printer
On my camera when i turn it on the lens keeps opening and closing and on my screen it says "turn off and on again" and when i do that the lens keeps opening and closing and it doesn't work. Can you help me...
This is the most common problem with dig cameras. The reason being that there are tiny gears inside the lens assembly, that operate it. When a tooth gets broken off, or some dirt, lint, sand, etc., gets in the lens assembly, a gear can get jammed. When this happens, the camera cannot "initialize" and be ready to take pictures. There is an excellent blog about this problem. It is listed under the lens error category, but it applies to all lens malfunctions, and the one you're having. Here it is:
Try their suggestions. They say about 50% of the cameras can be fixed trying their free fixes. If nothing works for you, and you decide to have it repaired, get an estimate first. The cost of repair can easily exceed the cost of a new camera. Good luck, and hope this helps!
Jun 18, 2010 | Cameras
Lens wont shut. camera will not power back on. battery good
slap it in your palm several times to release whatever is jamming the lens. EWhile this sounds brutal it is but I was given this tip bjy a Sony digital camera tech and believe me it does work,\\Keep trying till it eventually clears
Jul 22, 2009 | Cameras
Sliding Lens Door Problem -- Canon S50
I had the same problem with a S50, where the lens door would not operate properly and would not open enough to cause the camera to activate. I took it apart and found that there are two small gears that keep the door on track, one had split in half and jammed the mechanism. They were white plastic, perhaps nylon? I found another S50 on ebay with broken electronics but a working lens door and took parts from it to fix my system. Getting the tiny gear in place was tricky as there are several springs used to activate the camera on switch.
Jan 18, 2009 | Canon PowerShot S50 Digital Camera
Lens does not close anymore -
When you opened it the cog connected to the motor which opens and closes the lens probably shifted and no longer has traction against the ring around the inside of the lens which turns it to open and close it. If you open the camera up again be extremely careful - the lens has loads of springs inside it - lose one of these and it won't work properly. I opened up the whole thing to try and fix my lens which had been jammed in after a friend dropped it. I fixed the lens but couldn't put the damn thing back together again to many tiny parts and no guide to the jigsaw!!
Nov 16, 2008 | Casio EX-Z1050 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
No Image on display screen
Does the play back show any of the pictures you have taken before? are you sure the little lens cover is opening? there is a shield that closes down to keep the lens protected from debris and finger prints. Sometimes they can get jammed and not open. Tap on the front of the lens see if it opens. Switch it to auto mode if its not in auto mode.
Apr 04, 2006 | Sony Cyber-Shot DSC-F55 Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Olympus FE-230 Digital Camera Logo
69 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
