Question about Kitchen Ranges
I am trying to figure out exactly what is causing my kenmore model 110.77522600 gas dryer to do the following: timer not advancing in auto mode, heats up for five minutes the flame goes out, will not lite again until unit is cool then same thing happens. I have checked all the themostats and limit switches for continuity, they are good. Any suggestions. Thanks Mark
    Sergeant:
    Champion:
  • 351 Answers
Your cycling thermostat is not cycling going out on high limit that why it cool be be for it will re lite
Posted on Oct 02, 2010
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
Kenmore dryer model 110 does not stop during automatic cycle
Make sure the small orange wire is connected to the 250 limit at the base of the heater assy. That is what powers the motor on auto cycle.
Nov 27, 2013 | Kenmore Dryers
Dryer timer will not advance in any mode.. timed, or auto mode. Dryer works, but will not turn off unless you open door or advance timer. Do I need to replace the timer?
the timer will need to be replaced if it's stuck in the mode as you stated. the timer is built with cog teeth gears that rotate slowly as the timer operates normally. If a cog tooth breaks off the timer is stuck in that position causing your problem here
Jul 11, 2011 | Whirlpool LEB6200 Electric Dryer
Kenmore 70 series gas..no heat, timer will not advance except in timed mode.
What you do first is look for signs of air restrictions which could cause the limit/fuse to melt. Remedy that first. Then get meter and check all the components on the dryer for continuity. The part that don't have continuity is gonna be the problema. The number on suspect is gonna be this one:
If the fuse checks out check the components on the gas assembly:
More Here
Jul 09, 2011 | Kenmore 700 7973 Gas Dryer
My Kenmore 80 series dryer won't shut off. It only stops when the door is open. Model #: 110.72822101
In timed mode, the timer has most likely failed and is not advancing. In auto-drying mode, the timer or the moisture sensor has most likely failed.
Apr 05, 2010 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Motor runs, but timer does not advance, no heat.
if the timer is on auto it won't advance if there is no heat,you'll need a meter to read out parts in dryer,is it gas or electric?try first by checking the thermal fuse on the blower wheel housing,if that's good check the heater if it's electric,if it's gas check the ignitor,sensor gas coilssend model number and if it's gas or electric next time
Nov 28, 2009 | Kenmore 63942 Dryer
Kenmore gas dryer
is this in the auto mode or timed mode??
Jan 25, 2008 | Whirlpool LGV4634JQ Gas Dryer
Kenmore dryer
Jeff, almost sounds like a timer issue, but I was fooled on this once. Under the consol is a inline resistor from the main plug. If this resistor is bad, dryer keeps running in timed dry. Part number for the resistor is 3401076. Look it up on the web so you know what it looks like. Just splices in.. Catriver..post back.
Sep 14, 2006 | Kenmore 62602 Electric Dryer
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
