Question about Garden
I have a 2001 poulan wild thing saw, changing the fuel lines. not sure how the need to be routed.
    Scholar:
  • 71 Answers
I can describe it but see if you can follow this link which I uploaded a couple of weeks ago. If you cannot, just re-post and I'll describe it instead.
http://www.flickr.com/photos/29932328@N04/5021387817/
Posted on Oct 03, 2010
I finished changing the fuel lines on my Poulan wild thing chain saw and I need to see a breakdown of the routing of the new lines to see if I got them right.
Just remember the primer pulls fuel from the carb, into the bulb, and back to the tank, not the other way round, the longer of the two pipes on the primer is always the pressure side, so always goes back to tank, the shorter conection is the suction side so goes to the carb.
Jul 18, 2011 | Poulan 14" Chainsaw
WHAT IS THE FUEL LINE ROUTING FOR A POULAN 2375LE. IS THERE A ROUTING CHART?
The fuel line from the tank with the filter on the end, goes to the main fuel inlet on the carb, the conection nearest to the alloy pump cover held with a single screw, the other conection on the carb goes to the shorter of the two conections on the back of the primer ( the suction side ), the shorter of the two conections on the back of the primer ( the pressure side ) has a hose back to the tank, just remember the primer pulls fuel from the carb, into the primer, and then back to tank.
May 16, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need a routing map of the fuel lines for the wildthing 2375
There is no diagram that shows this, however i can tell you where they go, the fuel hose from the tank with the fuel filter on goes to the fuel inlet on the carb, the nozzel nearest to the pump side of the carb ( cover held with one screw ) the pipe from the carb nearest to the metering side ( cover held with four screws ) goes to the suction side of the primer ( short nozzel on primer ) there is then a pipe from the pressure side of the primer ( longest nozzel on the primer ) back to the tank ( just pushed into the top of the tank ), just remenber the primer pulls fuel from the carb, and dumps it back into the tank.
Mar 02, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is gas line routing Gas line broken in tank
Like the following link:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Typical 2375 IPL (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-7/75.2375-Gas-Saw-Type-7.1.59.1.html
All Poulan saws:
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 31, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
All my fuel lines fell apart. I do not know where they go.
All Poulans are similar, I am forced to believe your saw is a "2375 Type MyBestGuess".
An example IPL for a Poulan "2375 Gas Chain Saw Type 7" follows (may not be your saw):
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly: It is deceptive it appears the filtered line goes to the primer, it doe not! It connects to the carburetor input. Trace your existing lines and they will bear my fuel schematic out.
A typical fuel system and a couple of hints can be found here:
If your saw is not a Type 7, you can find the correct IPL here:
Poulan.com
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 04, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need a new primer bulb Poulan WildThing 42cc CS
Item 18 on the "Engine Assembly" detail IPL here:
http://www.ordertree.com/modelinfo/PWE/PP4218AVX-Gas-Saw/75.PP4218AVX-Gas-Saw.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
If this is not your saw you can fin d your here:
Poulan.com
HTH
Lou
Jan 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do you replace the fuel lines
This should help. Snap a photo then a small sample of each to your local chainsaw seller.
The link is a Poulan 2375 Gas Saw Type 7 IPL.
If not your saw you can find the correct one here:
Poulan.com
If you have more questions you can reply below. I hope this is helpful.
Lou
How do I hook up a fuel line to a carbuertor on a Poulan 18 inch?
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/thumbs/Lou98321/fuelsystem.jpg
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
Poulan.com
The dash number of your serial number is the type. HTH
Lou
Dec 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a Poulan 2375 chainsaw. The fuel lines became brittle and broke. I purchased new lines, but I need a diagram to see where the belong... there are two different size lines... but where the heck do...
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. It does show components and part numbers. Find it here:
Poulan.com
Typical fuel System:
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Nov 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
