Question about GE Spectra JBP78 Electric Kitchen Range
Oven want heat only on clean - GE Spectra JBP78 Electric Kitchen Range
    President:
  • 2,777 Answers
This sounds like a thermostat problem on the oven. It could also be a control unit though unfortunately. It is definitely indicative of a hardware failure inside the oven though and is not something you can remedy without replacing parts. I would recommend you have an appliance person come do it for you, it is not a simple repair by any means. That and they will be able to determine which part it is by swapping them out until the one works, there is no other way to know for sure. That equates to it being fairly expensive for you to try and do yourself unless you happen to get the right part on the first try.
But if you really want to, try the control unit first, then the thermostat. They can be found here, the control unit is labeled as T08 control on this page, but you can also see how complicated it is..:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=212110
Thanks!
Tim
Posted on Oct 02, 2010
Oven won't heat
You may have a blown thermal fuse in series with the heating elements. If the oven exceeded the maximum allowable temperature during self-clean, the fuse will open. See this discussion:
Oven Failure After Self Clean and F1 Errors
Aug 22, 2014 | KitchenAid Ovens
After cleaning the ovens with the self clean feature, the lower oven no longer heats up
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 l';'
Aug 05, 2011 | Thermador C272 Electric Double Oven
My heating elements are not heating for bake, broil or clean. just finished a round of self cleaning and now oven doesn't heat.
The self clean or self destruct mode has burnt a wire, the relay, or the control...
A tech with an electrical meter will need to check through the wiring and see what burnt up...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 13, 2010 | Whirlpool RBS275PD Electric Single Oven
Not heating up after cleaning
There is a thermal sensor mounted to the back of the oven if it over heats the sensor will disable the oven heating elements. replacing the part would allow the oven to heat but if you reuse the self cleaning it may go out again. some ovens need to be modified to prevent reoccurance during self cleaning cycle.
Mar 17, 2010 | Whirlpool RBS245PD Electric Single Oven
After using self clean oven will not heat on any setting
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 17, 2009 | Whirlpool RBS275PD Electric Single Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Cleaned oven now won't heat
Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
Aug 25, 2007 | Whirlpool RBS245PDS Electric Single Oven
GE Spectra JBP78 Electric Kitchen Range Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
