Question about Roper RAB2121KW Top Load Washer
Will not spin
Does everything but spin
  • 413 Answers
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch.
Posted on Jun 01, 2008
I have a dryer which stops spinning some times, I have to manually spin the drum for it to start again. This may happen several times during a cycle.
I assume you mean it still heats fine and everything? Tear it apart and see if the belt is in good condition and routed properly and that the pulley spins easily. If everything checks fine maybe you just have some bad spots in the motor. Good luck.
Apr 06, 2011 | Fisher Dryers
Everything works-no spin-motor sounds like it won't engage
Sounds like the clutch is malfunctioning. Not an easy DIY job -- probably need a service call.
May 31, 2009 | Roper RAX4232KQ Top Load Washer
Tub not spinning-everything still dripping wet
Sounds like the drive coupler between the motor and the gearcase assembly is bad causing no spin.
Go for the replacement Drive Coupler Kit
For more repair help go to: RepairClinic.com
Appliance parts, help & more
May 08, 2009 | Washing Machines
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Wont spin does everything else but spin
Your spin cycle control seems to be bad. This is also called your timer. Check for power supply by pulling off your top panel and checking for power everywhere.
Apr 17, 2009 | Crosley CAWC529JQ Top Load Washer
My washer isnt having a spin cycle it is only 4 months old what d
When the door switch is not making contact with the lid closed a washer will do everything but spin, remove the door switch and check it for continuity in the closed position, if it has continuity in the closed position the lid may not be pushing the switch all the way in when it's closed.
Apr 10, 2009 | Washing Machines
Power on but it won't spin.
Hello zurdo4ever
Welcome to Fixya
My name is Huum,
You said, power on , but it won't spin. hear a clicking noise in the motherboard.
Everything seems to work. except it won't spin.
The dryer was only spinning but not heating lately. need assistance
The clicking is a bad relay sound.
This is an electrical problem and it may be a need for a new cpb (Control panel Board) also.
time to get a tech in there to diagnose which problem you have and get you doing laundry again
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
UMD on PSP Slim will not spin
No idea, if its not spinning u definitely need to buy a new Laser Assembly. Sry!
Nov 13, 2008 | Sony PlayStation Portable (PSP) Slim...
Roper RAB2121KW Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
