Question about Bass Pro Boating
Minn kota edge 70 foot control lower half of upper control housing broke where it mounts on the shaft. looking for repair manual (how to replace and the part)
    Top Expert:
  • Bass Pro Master
  • 41,466 Answers
I have a Minn Kota Fortrex 80" Shaft 24volt motor. The shaft appears to have a lot of play where it connects to the top of the aluminium bracket at the head. How can I repair this?
what do you consider a lot of play
1/2 inch, 1", .02",040" or what
talk with a service agent for the equipment to get the exact amount of end play permissible or down load a workshop manual for the equipment
Mar 10, 2016 | Minn Kota Fortrex 80 Bow-Mount Trolling...
Minn kota riptide 55 bow mount with foot control and auto pilot. problem is prop doesn't seem to spin as fast so top speed is about half to two thirds of what it was when new. unit is about 5yrs old.just...
Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
Oct 16, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
I have to manually turn the prop. to get the Minn Kota electric motor to work. Once it gets going it works fine. What is the cause?
I have an all terrain 70 that would not work intermittently. I disassembled the motor and discovered that the brushes wer hung in the brush housing. The housing is clean and the brushes are in great shape. It appeared that the geometry of the brush spring is just right to make it hang at that prticular position. I freed the spring and could not recreate the problem. Reassembled with new gaskets and seals and all is good.
Jul 05, 2010 | Minn Kota Maxxum Pro 80 Freshwater Transom...
My minn kota riptide 55 stopped working when i turn the handle. i believe its a connection issue. i dismantled the housing around the handle and a little metal washer fell out broke in half and the pieces...
Hi!
To start with, here's a schematic:
RT55 Hand Control
Sounds like key# 87 broke....seen it before.
To replace it, remove top cover, then remove the handle portion by removing the 5 screws underneath. There are a few peices in there, so keep close watch. Also be careful of the fine ribbon wire attaching the handle to the control board...it's pretty fragile.
Best of luck!
Mike
Sep 27, 2009 | Minn Kota Riptide St Saltwater 55 Bow...
On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I cant adjust foot tension on minn kota edge
Hi!
Flip the foot pedal over and tighten the set screw where the cable enters, this should help out.
Here's a schematic:
Edga 40
Best of luck!
Mike
Jun 06, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
Can you wire a minn kota foot control
.....I think so ;)
Here's a schematic, complete with wiring diagram:
Maxxum 70 Bowmount
Best of luck!
Mike
Jun 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Possible sticking foot control switch
If you can undo the switch and it won't run any more, the it is the switch except for any other wiring short out of sight depending how that switch is hooked up. Strangely these devices should be designed to fail to safe. In your case some exception?
Apr 28, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn Kota electric motor MKJI1033962
Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
800-227-6433 they will help you with any technical questions.
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
=100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
Aug 10, 2008 | Minn Kota 40 Edge Bow Mount With Hand...
Boating Logo
205 people viewed this question
Top Bass Pro Boating Experts
ray gallant
choprboz5
vinayghl
Are you a Bass Pro Boating Expert? Answer questions, earn points and help others
