Question about John Deere Garden
Brake pedals are stuck down and cant be moved....
    Scholar:
  • 71 Answers
Will need the model number for best results, but insure that your parking brake lever is not still engaged. Typically a lever on or below the "dash". You would need to depress the foot brake and at the same time, release the parking brake handle.
Posted on Oct 03, 2010
2001. Which fuse is for the gas pedal brake pedal controls to move them up and down?
Adjustable pedal problem looking for part number or fix. - Ford ...
www.ford-trucks.com > ... > Expedition & Navigator
Feb 3, 2010 - The fuse is good....the pedals move about 1/2' but will not move to the... Does anyone know if a pedal assembly off of a 2001 fit a 2003? ... 2 9G604 Adjustable brake pedal switch ... The DSM constantly monitors the systems under itscontrol and ... I will keep my eye's out for anymore info on how to fix them. Parking brake light comes and goes
Apr 23, 2012
No Turn Signals, Hazards, or Brake Lights
Jul 4, 2011
Shifter stuck in park, Anti lock lite flashing
Apr 18, 2008
cruise control not working - Page 2
Nov 22, 2003
More results from www.ford-trucks.com
Dec 25, 2015 | Ford F-150 Cars & Trucks
My 2010 chevy hhr is stuck in park wont go into gear transmission auto I start the car push down on the brake and cant move the shifter at all cant put it in drive or any gear
Look on the brake pedal lever for an electric switch. Replace the switch and see if that works. If not, get under the vehicle and look for a loose wire on the transmission. If this doesn't work, you will have to take the vehicle to a transmission shop. There is likely a loose wire or a bad servo inside the transmission. But the shop will first run a diagnostic check. They will then know what the problem is and repair it.
Feb 03, 2015 | 2010 Chevrolet HHR
My 1991 buick park ave shifter is stuck in park,it cranks but cant move shifter to reverseod drive to move car,can you help,tony.
have you tried starting it . sitting in the seat and pushing down the brake pedal then the shifter .\while holding brake down. I do not have a buick but that is how chevy truck toyota car and toyota truck work
Feb 03, 2015 | 1991 Buick Park Avenue
Brake pedal stuck down
Pull the pedal back up as the problem is air in the system. You may have to do this until the air starts to move out of the system. IT would be advisable to prime the master cylinder before fitting it as this overcomes the problem of trying to get the cylinder to pump up.
Nov 17, 2013 | 2001 Dodge Ram 3500 Truck
Rear break pedal does not move
If the brake pedal is stuck, but moves ok when brake line is disconnected, then the problem is further up-line!
Check brake caliper to see if that's the problem.
Aug 11, 2013 | Harley Davidson Motorcycles
1969 Kenworth Dump Truck. Not much movement in brake pedal. Does not appear to have air to the pedal. All other air works fine.
Spray brake pedal (treadel valve) With WD-40. May have to remove foot pedal and rubber boot work up and down with pliers until moves freely.
Apr 14, 2013 | Cars & Trucks
My brake pedal gets stuck, and the car still be moving, but after about 30 seconds it releases, what causes this please help me.
Your pedal is going down too far perhaps. if it is, you may ned to have your brake pads and rotors checked out.
Mar 21, 2010 | 1999 Pontiac Grand Prix
4.2l. Why is shifter stuck?
With the car started press on the brake pedal. Listen carefully for a "Click" sound coming from under the gear shift cover. If you do not hear one you will need to test the brake pedal switch, if you hear a click then most likely the lock somehow became disconnected from the solenoid. Remove the shifter cover and the assemble is can be seen for troubleshooting and repair.
Aug 14, 2009 | 2005 Jaguar S-Type
I cant get the gear shift out of park. Its like it stuck
Push down on brake pedal with ignition switched on.If it still want shift then you have a problem with the pedal switch.Or maybe you battery needs recharging.Hope that helps.
Jul 24, 2009 | 2002 Volkswagen Jetta TDI
Garden Logo
487 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
